Just posting updates
Finally got around to getting my 07 5AT 370gt Coupe tuned at East coast customs.
My only performance mods are Cold air intake (z1) and a Twin x Pipe cat back Exhaust.
My car was tuned with 167kms on the clock and made great power imo
In the end i made 218rwkw with 325nm of torque.
Super happy with the work carried out and Quite happy with the power that managed to come through the 5AT.
I wasnt risking an e-tune to get over the 300hp mark etc
https://www.sau.com.au/forums/topic/478543-vq-tune-results/
56 minutes ago, KiwiRS4T said:
So how do you tune a VQ37? Do you have piggy back devices, an aftermarket ECU or is there a replacement tune-able chip in your ECU?
Uprev tuned my friend. Stock ecu is tunable :)
  • Like 1
https://www.sau.com.au/forums/topic/478543-vq-tune-results/#findComment-7914992
1 hour ago, LesF said:
I thought the 370GT was already rated at 325 hp.
Guess I should get mine checked out sometime to see what it does put out.
it is but not at the wheels. The 325HP is at the fly.
https://www.sau.com.au/forums/topic/478543-vq-tune-results/#findComment-7915756
now i've gone from 325 at the crank to around 355 and the cars alot more responsive.
Edit - Keep in mind the cars 12 years old. Its 325 at the crank wasnt that accurate anymore. Dyno'd in at 316 to the crank.
Edited by DashyyPC
https://www.sau.com.au/forums/topic/478543-vq-tune-results/#findComment-7915757
Ok.  I am considering doing something with mine... traded in a 300ZX TT for it, which was around 340 hp at the wheel (I still shed a tear when I see a nice Z go by, but both myself and the Fairlady were getting old)  anyways, the VQ37 is quite impressive, but I wouldn't mind a little more torque starting off, probably not going so far as to start looking at turbo/supercharger options.
https://www.sau.com.au/forums/topic/478543-vq-tune-results/#findComment-7915765
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
