Hi all,
First post here but I have a 1990 R32 GTR with a small power steering leak coming from the high pressure hose leading out of the power steering pump. I had the PS fluid flushed and replaced earlier this year and this leak seems to have developed within the last few months. The car drives fine and doesn't make any strange noises but will leave a few drops on the floor after turning into a parking spot. I got under the car and identified where the leak is coming from as shown in the photo here (the dark streak on the left is the dribble of PS fluid from where the hose meets the metal fitting). 797251782_WeChatImage_20190909171832.thumb.jpg.3d667d5d508af8d269cd3077ee213182.jpgI've attached another image of the part and the leak area circled in red.
My question is, would it be possible to tighten the metal fitting to stop the leak and if so, how would I go about it? Second, I don't mind buying the whole high pressure PS assembly pictured and swapping it all out as a preventative measure (as I can't find the rubber hose/metal fitting alone), but would this be something that can be done just by getting under the car or would the engine/large components need to be removed first? Thanks for any insight you may have!
Edited by nouveau_poor
rewording
https://www.sau.com.au/forums/topic/478626-r32-gtr-power-steering-leak/
Thanks for the reply. I read somewhere else something about a crush washer deteriorating over time leading to a leak but that might not be applicable to the fitting in question. If the swap can be done without removing the engine or major parts I'll do it myself or ask my mechanic. In the meantime, has anyone had luck using power steering additives to stop small leaks like this?
Well I'll go ahead and order the assembly if the rubber hose can't be saved. Hopefully replacement isn't too difficult and labor costs aren't too high. I don't enjoy having to top off my PS fluid all the time. I'll try to keep the thread updated when I get around to installing.
You could just remove the assembly and take it to a hydraulic hose shop and they could put on a new bit of hose in a few minutes. Obviously you would discuss this with them in advance and show them the picture and book a time to walk it in....
But it would save you the arse raping that you'll probably have to endure to buy the whole thing.
  • Like 2
Hydraulic shop, Enzed, Pirtek...they will make it while you look on in amazement.  Take about 15 minutes....ie a hellava lot quicker than you when you have to remove and refit it, that will take you half a day and skun knuckles.
That's some good advice about the hydraulics shop, I'll keep it on my radar. It does sound a lot less painful to just fix the rubber itself. A local shop is selling the whole pipe for a tad less than from Nissan so I was thinking that replacing it all with OEM would be good for the long run. Is the rubber hose alone removed from where it meets the hard line by the first metal plate/bracket? If so, I'm surprised that Nissan doesn't sell the hose alone if the whole pipe can be disassembled like that.
The hose is crimped onto the hardpipe ends. It's non-trivial to remove and refit.....unless you're at a hydraulics place.
So an update as promised. I ended up going the full assembly route as i figure it's long-term insurance and I would have had to pay someone to remove the old assembly anyway and so the price difference between a repaired hose +install and a new OEM part + install was worth it to me. I took a peek under the car beforehand to see if I could remove and reinstall myself but could not for the life of me find a straightforward way to weave the bends and everything around the steering rack. Dropped it off at my usual shop for a day and got it back a bit ago. No leaks (as one would hope) and I don't think they had to remove neighboring bits to do it. Not sure what kind of witchcraft they used but it went in the same way the old one did. Ideally it should be good now for another 30 years right? Pictures of it snaking around below:
It goes behind around all this stuff
The switch/plug for the high pressure line
Here you can see the leak flowing down the hose before it turns into hard line again
3 pipes go into the power steering rack assembly. The one replaced is the center one.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
