Hey All!
Wondering if anyone can help me, had some rain here recently and noticed water got into the cabin. I'm pretty sure it happened while it was parked and not driving. It's only in the driver side footwell and I've checked the fire wall and there is no obvious place for water to enter (such as a grommet or such.
Have pulled the carpet back and it looks like it's leaking from the centre console maybe? Just wondering if anyone has had a similar issue or has any thoughts on where this could be from?
The water patch seems to be from the left of the clutch pedal against the gearbox tunnel (can see the discolouration on the photo.
Any help would be sooo good :) (is in a R34 GTT)
Edited by Tobz
https://www.sau.com.au/forums/topic/478751-water-leak-to-cabin-any-ideas/
7 minutes ago, GTSBoy said:
  • Windscreen seal.
  • Plenum chamber drains blocked.
Makes sense. I'll try and see if either of those are the issue.... Is there an easy way to check either? I had a look at the windscreen but it's hard to tell if the seal is 100%
I'll have a bit of a google
@GTSBoy
Ok pulled the car apart, finally have located the rough place of the water entry
The water seems to be dropping from above the throttle pedal. I'm thinking it's the windscreen?
Also cleaned up what I think are the plenums? They had leafs but nothing major. Picture also attached
Edited by Tobz
1 hour ago, GTSBoy said:
There's so much visible rust there that the windscreen lip is bound to have rusted.
It was all just black grime there, took me 20 mins to clean it back to this. Will probably sand it back and paint it up later this week
If it is leaking at the firewall near the accelerator then you have to take the front wheel off, then remove the plastic guard liner [screws and clips].  Behind this there are a few grommets and such for gauges and cables etc.  You won't see these grommets in the engine bay.  I'll bet that one of the grommets has been split for aftermarket gauges or boost controller.  Silastic out of a caulking gun works.....well did for me....but that was almost 20 years ago.
  • Like 2
Cheers! I'll try that first before the windscreen! Worth trying the cheaper options first!
  • 4 weeks later...
Ive had this problem as well but only happens when driving in the rain
  • 2 months later...
It was 100% this. Took me a while to get to it, but pulled it apart and found that the guys who did the alarm used the grommet there and just used masking tape to cover it. Tape loosened and formed a funnel which flowed the water into the cabin. Used some loctite putty thing and sealed it up good!
  • Like 1
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
