RB26 head (complete minus covers and cam gears) would require a refresh... - $750 ($850 with HD valve springs)
RB25 long motor (no hot side) Low compression on cylinder #5, would suit rebuild or RB30 twin cam... - $750
Complete S15 rear subframe... - $750
Brand new KKR adjustable rear toe arms (suit R32, S13 etc)... - $125
Defi gauges with controller (boost, oil pressure, oil temperature)... - $700
BBS forged wheels (260rs Stagea) with crappy tyres (17 x 7 +20 and +30) painted... $400
Can potentially post at buyers expense gauges, toe arms, wheels and maybe RB26 head...
Located South of Adelaide...
Edited by mr_rbman
wrong pic
  • 3 weeks later...
Added pics of Defi gauges...
https://www.defi-shop.com/products/advance_bf/summary_adbf/
(amber red model)
Edited by mr_rbman
added link
  • 3 months later...
  • 4 weeks later...
On 2/7/2020 at 7:14 PM, Jacks red r34 gtt said:
Hi mate if offer still stands I'll be happy to take that 25 neo motor of you
hi mate, the motor is from an R33, not 34 so not a neo...
  • 4 weeks later...
hey mate interested in the defi gauges as a gift for my wifes car!, if your willing to ship to Canada I will cover shipping and your time...thanks m8
no probs at all.
pm sent
  • 5 months later...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
