Hi guys, the opportunity has come up to buy the turbo, manifolds, dump pipe etc from an M35 Stagea for pretty cheap.
I've read that this setup bolts straight up to a V35 coupe but cant really find much info on the matter.
Has anyone done this, or confirm it can actually be done?
There was no turbo option on the M35 Stagea VQ35 so it must be some kind of aftermarket kit so as long as you are getting the complete kit including ECU. loom etc I can see no reason why it would not work on the V35 Skyline but double check everything first and ask questions of the seller.
I beg to differ, this statement is wrong. The NM35 from october 2001 to August 2004 was available as a turbo, all vehicles were 5speed automatics and were either available with HICAS or IRS. The usual problems with loom, High compression, injectors and ECU could be expected with this conversion.
They came with a VQ25DET aswell -  Afaik alot of this turbo set up is pretty straight forward when putting it onto a VQ35.
Read up on it a few years back.
If parts are cheap give it a go :P
Yuh, so Kiwi's statement is still correct. He said "no turbo option on the M35 Stagea VQ35 ". The operative bit being VQ35.
So the real question is "can you bolt VQ25DET stuff onto VQ35 (NA)?". And, I am 110% sure that this question has been asked on here a number of times before. Just search!
Edited by GTSBoy
'coz I stuffed something up and had to ninja edit it while I still could!
Sorry guys,  I should have been more specific. The turbo setup is coming from a VQ25 DET and will be fitted to my VQ35.
I actually had a chat last night with someone that's done it and looks like it's relatively straight forward.
I've already committed to the purchase, so a build thread may be incoming...
  • 4 weeks later...
@camr33 I had since looked into this as im friends with the guy who sold you the parts.
Xr6T Intercooler will fit fine along with the M35 stega set up. Only a little bit of work needs to be done. Makes the DE actually look cool with a big single turbo.
Yeah, I did some research prior to purchasing and spoke to a couple of others who've done it. Already have the intercooler sorted too. Just need to work out engine management, injectors and fuel pump next.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
