couchboy Posted October 29, 2019 Share Posted October 29, 2019 Hi guys Can anybody tell me if this is a hicas or non hicas power steer unit Link to comment https://www.sau.com.au/forums/topic/479050-power-steering-system/ Share on other sites More sharing options...
Duncan Posted October 29, 2019 Share Posted October 29, 2019 r32 hicas has 2 outlets from the power steer pump...and that pic (while difficult to see clearly), seems to have 2 outlets. Link to comment https://www.sau.com.au/forums/topic/479050-power-steering-system/#findComment-7918735 Share on other sites More sharing options...
KiwiRS4T Posted October 29, 2019 Share Posted October 29, 2019 Please do not start a new thread every time you post. Keep them in one place. Link to comment https://www.sau.com.au/forums/topic/479050-power-steering-system/#findComment-7918739 Share on other sites More sharing options...
couchboy Posted October 29, 2019 Author Share Posted October 29, 2019 8 hours ago, Duncan said: r32 hicas has 2 outlets from the power steer pump...and that pic (while difficult to see clearly), seems to have 2 outlets. Cheers Duncan I'm in middle of sorting out my power steer system in my race car, have you had any issues with yours or have you gone aftermarket? Link to comment https://www.sau.com.au/forums/topic/479050-power-steering-system/#findComment-7918757 Share on other sites More sharing options...
Duncan Posted October 29, 2019 Share Posted October 29, 2019 I'm limited in what I can change by production car rules, I have to run standard pump but can (and have) changed the pulley to underdriven. I had issues with leaking from the cap until I added a reasonable sized cooler but it has been OK since. HICAS is removed and so are the vanes in the rear stage of the pump so it doesn't die from pushing against the blocked off line. I also lost a belt once but NFI why as nothing had changed recently, and only once in 10 years race/rally Link to comment https://www.sau.com.au/forums/topic/479050-power-steering-system/#findComment-7918765 Share on other sites More sharing options...
couchboy Posted November 1, 2019 Author Share Posted November 1, 2019 Ok so I'm looking at replacing the power steer reservoir with a aftermarket one, I found this one with a an10 feed and a an6 return, my question is does it matter were the return is? Link to comment https://www.sau.com.au/forums/topic/479050-power-steering-system/#findComment-7918923 Share on other sites More sharing options...
Shoota_77 Posted November 1, 2019 Share Posted November 1, 2019 Yes. Particularly for a race car that will see high revs. Make sure it’s a baffled reservoir that is designed to slow the oil down upon return. I’m not sure if it’s foaming (fine bubbles) or the speed that the oil is hit the reservoir but either way it needs an internal method of controlling it or you’ll have oil everywhere after a few laps. Link to comment https://www.sau.com.au/forums/topic/479050-power-steering-system/#findComment-7918924 Share on other sites More sharing options...
