I forgot to post this a few weeks ago.
My car was the volunteer car for JDM Accessories parts including their new wheels.
They're a fair but chunkier than stock but deffs worth the upgrade. Been running for over a month now and it's way nicer to use than stock.
Would recommend for the price.
This isn't a sale post. Just a recommendation incase you get the usual trash quality v36 wheel.
Mention  me when you purchase and he may even give you a discount :)
  • Like 2
https://www.sau.com.au/forums/topic/479110-v36-steering-wheel/
Do they have a better button bezel such that the paint doesn't scratch off the plastic so damn easily?
Also, does it feel weird at all with the flat bottom when doing full turns? I just can't help but think the discontinuity in the shape would feel a bit odd.
I've had  steering wheels and my friend has also has 2 and none of them have ever had this scratching issue.. i find it weird that its so "common" yet we've been through 4 and never once had the issue.
It doesn't come with those, you transplant those from the old wheel. Only takes 15 mins to do (super simple DIY)
You actually dont really notice it. It was weird the first 3 or 4 times but you easily adjust.
So I'll have to get mine wrapped then.
I haven't scratched mine but it did have a couple of scratches on it already. Maybe the previous owner didn't clip their fingernails regularly? :)
Care to message me the link to the supplier? I'm keen to know how much it'll cost me. Would be nice to have a fatter wheel.
The button Bezel on my 370 was pretty well scratched when I purchased the car. Purchased a new Bezel using Amayama. Better quality, will not scratch. Let me know if you want the part number.
I'm all ears, as I've been dubious about replacing it with another OEM one in case if it's the same materials/coatings. I was going to get mine wrapped.
Just checking, this is the bezel with cutouts for just the buttons on the left side for the stereo control, phone, back button and voice control, yeah?
Edited by The Max
Yeah the part you will get is definitely an upgrade in quality. In fact its nearly impossible to scratch I reckon.
Part Number ; COVER,PLASTIC Nissan 48463JK00A is without the buttons. A bit of google or put that part number into Amayama or Partsouq and you will find yours.
If you youtube steering wheel removal G37 or similar you will find a DYI on how to remove the steering wheel. IT takes about 15 mins with the right tools.
From memory you will need a 1/4 Socket and a T20H torx driver.
Good Luck.
Edited by SOO06E
If 48463JK00A is without the buttons, that will not be suitable for me, as I have buttons on the left side of the wheel and so the bezel needs to have the cutouts to accommodate them.
I think I'll just remove my wheel one day, disassemble it and look for the part number imprinted on it.
Lol i think he means its just the shroud without the buttons
As in you dont get the literal buttons. Cutout will still be there.
Also super easy to take off. Would be alot easier to take apart and Repaint/Wrap it yourself compared to buying a new one.
That's what I was hoping he meant, despite the fact I explicitly asked about the cutouts and not the actual (not literal) buttons themselves. Yes, I know I'm a grammar nazi but I just hate the overly misused word, "literal".
Anyway, the reason why I'm a little concerned is that when I looked up the data for that part number in two different drawings from Nissan's EPC sheets, the same part number appeared with the cutouts in one drawing (possibly hinting at cruise control on the right side) and no cutouts at all in another drawing (as well as no button cluster).
Given all that, you can see why with so much ambiguity from user and manufacturer alike, I'm a little dubious.
I have a spare one at home. when i get home ill get you the part number from it.
Legend. Thanks dude.
For anyone else who may be curious, Amayama seem to be the only guys carrying that particular part number. That being said, when I search based on my VIN, it claims to be a 48463-JK01A instead of 48463-JK00A. Luckily Amayama carries that one too. I already checked with Partsouq and they carry neither.
  • 7 months later...
  • 1 year later...
  • 5 weeks later...
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
