Hi guys,
i'm going to get off my stock turbo an put on a Garrett GTX3076.
Other mods like FMIC, 600 cc injectors, link g4+, DW fuelpump etc. will be or were already added.
So I took the head off and got it machined to have an even surface. I've cleaned the block with a razorblade to get off the rest of the oem headgasket. The machine shop took off 0.16 mm from the head to get an even surface. The oem gasket thickness is 1.2 mm as I've read, so if I add the 0.16 mm the replacement has to be at least 1.36 mm. Correct?
As I am from Germany, i've searched for a metal headgasket in the local online shops but just found 1.2 or 1.5 mm but no 1.4 or 1.3.
So which thickness would you recommend? Or would the oem Nissan gasket be good enough for my setup, keeping in mind that the block was only cleaned by hand?
Ok, thnks for the info. Is this the correct one? https://www.tj-partshop.com/products/13009-Tomei_Headgasket_Zylinderkopfdichtung_Nissan_RB25DET
It is available with 1.2 or 1.5 mm. Which thickness would be the right choice?
The Tomei compression rate calculator says that the oem gasket thckness is 1.1 mm and the compression is 8.97.
With the 1.2 mm gasket the compression rate would be 9.03 and with the 1.5 mm it would be 8.76.
1 hour ago, GTSBoy said:
How can a thicker gasket increase compression ratio?
I've clculated the compression ratio value for the 1.2 mm including the 0.16 mm of material that the machine shop removed from the head.
When I use the 1.2 mm gasket it will be the same as 1.04 mm gasket with the cylinder head before machining it.
get 1.2mm
It's 2019 not 1979 where we have shitty ECUs :)
2 hours ago, AngryRB said:
Just get a stock RB25 head gasket and ARP studs..
You know a Tomei or Nitto head gasket is much more? Not to mention it's better than the stock composite head gasket.
I know my RB3025 has no issues at 350kw, is a simple oem RB26 gasket that was very reasonable cost from Kudos with ARP studs..
If the block surface isnt perfect then it could leak and after pulling engines out a few times recently im over that bullshit so id advice OP to keep it simple.
You clearly missed what I said earlier about Tomei or Nitto head gaskets ?
How I see it is you've spent that money/time to take off the head and skim it, purchased a larger turbo and going to run ARP studs (over the factory head bolts), then what's an extra $200 to the equation? not much.
Not to mention the Nitto OR Tomei headgasket will seal better and also will withstand the punishment as it's o-ringed. Every car workshop does the same thing. I also got told this advice from both MRC and Billtech (both reputable RB workshops).
I would only advise going with a Cometic or similar style headgasket if your block is prepped.
12 minutes ago, GTSBoy said:
Or perhaps the correct grammar version where you advise against it?
FUUARK - this is proof Asian Males cannot multitask, was typing out an e-mail to a vendor at the same time about "advising" shit too LOLOLOL
(have edited the previous failed post)
Thanks @GTSBoy
Thank you all for the replies. This forum is much better than the german equivalent.
ARP studs are already in my garage waiting for me to screw them into the block. I think I'll go for the tomei gasket because of the small extra cost but higher (presumed) reliability compared to the oem gasket.
Will the higher compression ratio be an issue when mapping the link ecu because of the risk of knocking? Keeping in mind that the stock knocksensors will stay in the block.
By the way, what do you think about applying permatex spay gasket to the tomei gasket before assembly? Does it help to get a better sealing, or is it just wasted money?
Edited by Finn_GT-T
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
