  • Replies 219
Yeah rob what he said. The kits were measured out to give you enough hose to fit it in the front bar. I fitted it in the gargae at my place and just used some aluminium to make up the brackets. Mine is the standard GTS kit.
Nope....
Have got 3 pm's for definate's. If you speak to or can speak to any of the other interested parties please do, as the track day will sneak up on us quicker than you expect and we should get this moving.
1. INASNT
2. Daz
3. Ronin 09
Ok, Email sent to Toby awaiting reply for stock levels and confirmation of pricing.
1. INASNT
2. Daz
3. Ronin 09
4. Croat
5. GTTR34
If there is anyone else please PM me ASAP.
Toby has advised that he will have all the parts for everyones kit by Monday.
He has told me to pass on that the $440 price will include 2x Straight Fittings and 2x 90 Degree fittings, a cooler, billet adapter, and 2.5m of hose.
I think that the 2x 90 will go on the cooler if mounting in front bar and the 2x0 can come out of the block providing nothing is in the way. If you think you will require 2x45 instead of 2x0 for this then the price will increase slightly.
Al found that the 4x45's were the way to go for mounting in front of radiator. But people can feel free to make up their own minds about what fittings they require and Toby will adjust the price accordingly.
I think that the straight fittings will suit most people. But you should have a look at your own engine bay and decide.
Dumb arse question from the guy from the back:
When i do an oil change, how do I ensure that
1. the cooler is drained of oil?
2. the cooler fills back with correct quantity of oil once I have changed the oil?
:P
Will let you guys know as soon as Toby is ready to go. I want to confirm everything with him before getting money in case there is any slight price change.
When I change my oil I will have to disconnect the cooler and turn it upside down to empty it of oil. But I wasn't going to bother too much. I change mine quite often anyway. There is no prolem with mounting the cooler upside down, which would make empting easier. But then filling it up on startup after the oil change would be harder work for your engine. When putting the kit together I would recommend filling the core with oil before connecting the hoses to help eliminate any surge issues. But two seconds after your car starts the cooler will be full and will stay full all the time, unless it's mounted above the oil level. In the case of mounting it in front of radiator it may get some drain back over time.
Which ever way you decide to mount it will work fine. After installing a cooler I'd say wait a lot longer before driving off once the car is started to make sure oil pressure is up. Dont just start and go staight away.
Ok Toby has all the parts required to make all the kits.
If anyone needs to change to 2x45 degree fittings over the original kits straight fittings there is an additional $46 cost
Ronin09 and GTTR34 - Please contact Toby directly to arrange payment ([email protected], 03 9553 4200.)
INASNT, Daz and Croat you have PM regarding payment.
Spoke to Toby yesterday, my car is being fitted up on Friday :)
Cheers Chris
EDIT - cooler fitted... bit*h of a job apparently.
32GTRs suck to fit anything to!
Haven't given it a cane yet, but will do on weekend
What does the probe look like? Might be hard to get it in cause all the fittings are designed to be very tight. It would be worth while speaking to toby about that. I'd say he would have some good sugestions.
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
