Both ECUS were running and the car was operational, all wiring has been checked and found to be in perfect order, this is what I've been told and have no reason to dought it.But in the back of my mind I wonder,so we will find out when the third one goes in soon. I was surprised that adaptronic was going to swap it with one of the haltech units but very disappointed they wernt going to chip in with the dyno needed to tune that ECU, after spending a hell of a lot of money I need to ease up a bit and get some driving time in and enjoy what is a awesome car, after all I wanted a new ECU for greater protection for my motor and peace of mind.
Wiring was checked, but was the voltage checked?
Why would they pay for dyno time? it's like DeWalt sells you a drill, then replaces it with the new Dewalt XR series and you ask them to build you a new garage (bad analogy but you get the idea).
when a problem arises its not as simple as some think, they have to find whats going on, which means time and money spent. the second unit put in still has to be put on the dyno and run to make sure everything is running properly, there's more time and money, that's my point. That would have to be one of the worst analogy's I've ever herd.If indeed the units were faulty I should be reimbursed for the time and money having to find the issues but I know that's not the way it works but I thought it was worth a try.You carn't just send the ECU back to them for a exchange without logs and the issues at hand. this is time consuming and someone will end up out of pocket.
Yeah I remember calling them last year as I'd heard good things about them. I thought they were the most arrogant, up themselves lot ever. I mentioned swapping from FC d Jetro to Haltech Elite and they basically scoffed at me for even suggesting it.
  • Like 1
I here you, its a shame at the end of the day your one tiny little peace of the puzzle they couldn't give a rats about, but they have made a big mistake this time treating a reputable business the way they have, its only going to hurt them in the long run.Word of mouth is a powerful thing.
Put it this way, you don't see many fast cars (Drag/Coota/Roll Racing/Circuit/WTAC) using a PowerFC, but if a shop insists on using a PowerFC then yeah.
Yes it might make the power, but there's no engine protection, no spare I/Os, no closed loop strategies, no anything really.
spot on Johnny, when we spend outrages amount's off money on built engines we need as many protections as possible,as you have just stated these are what all new ECUS provide today and is what people want nomatter what ECU brand they buy.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
