Hello everyone! Hope you're all going well and enjoying life n shit! ?
So I totally didn't realise Wheels was on this weekend and I will be in town so I thought I might stop past on my way home. Will there be any Skylines there or are we all too slack these days? ??
https://www.sau.com.au/forums/topic/479859-wheels-2020/
  • 1 month later...
I moved to the area in the last year - but mine doesn't get out much.
It's a bit sad how much the Skyline scene has died all over the country from what I've seen.   It had pretty much died in South Australia before I left - and it's sad to see it's not much better here.
https://www.sau.com.au/forums/topic/479859-wheels-2020/#findComment-7929016
There is a rising sun facebook group and a japx group on facebook. So that is better than nothing
https://www.sau.com.au/forums/topic/479859-wheels-2020/#findComment-7929264
Last time I went to a japx meet there was probably a dozen skylines there.... so defo the place to be. BooSTeRS is also pretty good, was originally just for the focus’ but has really branches out!
https://www.sau.com.au/forums/topic/479859-wheels-2020/#findComment-7929710
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
