Looking for more bang for buck here. Goal is 270rwkws w/stock internals rb25det and I'd imagine close to 20psi. With all the other obvious bolt ons taken care of- what will give me a better power curve for the money? An adjustable exhaust cam gear or drop in tomei poncams? Or better to just save money and spend elsewhere? I think I'd be happy with at least 10kws gained in the band, but more than that and I'd definitely buy one or the other depending on the answers I get. Cheers
Bigger turbo. For a small increase an adjustable exhaust cam gear may give you a little. Bolt-ons that are obvious to one person may not be to another. What have you actually done?
Hyper gear. Fmic. Z32 maf. Coil packs. 740cc Injectors. Apexi pfc. Full 3.5 exhuast. Ebc. Then a tune. Might be missing something else. That's the list, currently deployed so spending my downtime day dreaming and making a list of items for my r33. I guess my question should be this- let's say with those mods making 270rwkws what can I expect to see from an adjustable cam gear vs. Tomei poncams? 10kws here vs 15 there? Rough estimates will do, much appreciated
Run E85 is the best bang for buck.
Bigger cams will just bring the powerband towards the right hand side of your RPM graph.
I would say, get it all running 1st, then get Poncams if you're not happy.
270kW with stock cams is a walk a in the park.
I did 372kW with stock cams, 1.7bar of boost on a stock unopened motor for nearly 2 years with track abuse before it exploded lol
That's impressive!
50 minutes ago, GTSBoy said:
How big are the prizes in your race category?
Haha that's a good question. Dont intend to race the car atm. But in the distant future I may go up to 500+bhp and was wondering if it's worth a purchase then
    • So I actually had the cover off my car today, here is a (bad) pic of the setup. I have an oil cooler thermostat block, the temp sender is straight in there. The pressure sender has a short AN line to a T piece which is mounted (hopefully cable tied counts as mounted....) on the chassis. BTW every fitting you could ever imagine exists....just depends what they cost and how many you need. Raceworx AN adapters are here: https://raceworks.com.au/fittings/adapters/, I think you said you need BSPT to AN (https://raceworks.com.au/fittings/adapters/bsp/tapered/an-to-bspt-adapters/) and AN to NPT (https://raceworks.com.au/fittings/adapters/npt/) BTW, braided line is super simple to make. It looks intimidating, is not.
    • Perfect day for a pie, really needs a soft top in this weather though
    • Prime parking, she is a little girl...LOL
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
