Hi all. I have a R34 gtt with non working oem triple gauges. I found the white connector connected to the triple gauge, but it only has 2 wires attached to it. (+ and gnd, so alternator gauge works)
I think some previous owner added it to the wireloom
Does anyone recognize the Grey connector? It's laying underneath the gauges, not connected. Does it maybe hold the wires to cut and connect for oil temp and turbo pressure gauge?
I know what pins the wires have to go to on the white connector, but I don't know which wires to use from the Grey one.
Thank you!
https://www.sau.com.au/forums/topic/480047-r34-gtt-triple-meter/
The oil temp is really the only one that does work well, but others work better, can have clearer/more resolution.. The boost gauge isn't really up to the task, and battery voltage is... probably not worth having a slot.
My car is N/A now (v8 life) and I have water temp, oil temp, and an AFR gauge there.
When it was turbo, I had Oil temp, boost, water temp. Back when it was Auto and Turbo I had 6 gauges, the 3 up top as well as AFR, Oil temp, and Transmission oil temp. Yes 3x oil temp sensors ?
But the main one is it will be easier to install aftermarket ones.
I have an R32, so no triple gauge to start with. But in that location I have EGT pre-turbo, boost and oil temp. I consider those to be a sensible selection that will tell me most of what's going on. Could obviously add several others, but wouldn't want to make the car look F&F.
Now I have an ODB2 engine, I have a double din full android head unit, so I can run torque and show any gauges I want! ?
To the OP though, the point I was trying to make that in the future, they too will probably want different gauges/change the gauges there... so don't waste too much time getting the stock gauges working when most replace them anyway. Skip the middle man.
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
