On 21/07/2022 at 5:24 PM, Kinkstaah said:
That reminds me, why did I use all of the ports on the valve covers when I could neaten it and just use the PCV like you have done.
Cause.. flow? Ugh. Looks nice man. Much nicer than mine!
I asked about this when Autotech put the blower on, this is the way Harrop has the installation, the drivers rear breather is plugged, the passenger rear breather goes to a PCV valve then the intake, the front drivers fresh air is still there plumbed in to the intake as well
I asked about if it would restrict the flow, both Harrop and Autotech said it was fine and a single 3/8" line is more than enough, because thats what it basically has stock, well, my rear main is still where it is meant to be, and the dip stick stays in its tube
The standard valve cover vents go from 2 x 3/8 to 1 x 3/8 line with a PCV valve  into the TB
On 21/07/2022 at 6:59 PM, Ben C34 said:
Why are you so worried about heat man?
It's not like they burst into flames. It is like 20yrs old and hasn't burnt down yet.
Because I'm bored and want to play around, plus they have heat shields standard
I assume an engineer smarter than me thought it was a good idea, and it got past the people holding the purse strings, so they thought it was necessary as well
I asked myself "why do OEM exhaust manifolds all have heat sheild, and why does nearly every modified car doesn't have one"
My conclusion for OEM was the smarter than me engineer senario above
For the modified cars, my conclusion was it doesn't add HP for the money and time, so alot people don't bother, until they melt wiring or other stuff
Meh, I've got a heap of the sheilding for a few attempts, worse case senario is I hate it and start looking at V4.0, or, some other random thing that the voices in my head think is a good idea.........
(I wonder what a 4" exhaust would sound like compared to the current 3.5" single ?????)
  • Like 1
The earlier LS1's do that, the newer ones (like mine) have the PCV valve in the valley cover, so the only hose they have stock is the under-valley one to the intake manifold.
My one came with a nightmare combination of both vents and a newer PCV. You need to have the one from the throttle body on. I plugged it and exploded my dipstick at the track N/A because I was thinking boost land with a one way valve. Well it turns out crankcase pressure when it builds vents in the other direction into the intake manifold, so it's both fresh air and a vent. So don't mess with that one lol.
  • Like 1
Found my next pointless mod
Purchased a RU-3130 for $50 with a 3.5" flange, LOL, I said flange.... >s-l400.thumb.jpg.eb2ca6d47f73db04ffae08b68a874e65.jpg
Plus some composite sheet and pinchweld to look like >
0e53602e-a8c4-439f-89c1-a4a9c0ed3d6b.medium.thumb.jpg.f2aae5c63b9cde1f35e8800693c93d9d.jpg
Why, maybe more induction noise, and a day of making templates, drinking beer and possibly even some wrinkle coat paint splashed about
  • Like 2
On 23/07/2022 at 12:31 AM, Dose Pipe Sutututu said:
Maybe you should buy Lego, same feeling, less money lol
Have you ever stepped on Lego?
That stuff is dangerous and I won't have it anywhere near me
Plus cars and motorbikes are like Meccano and Lego for adults
Going to WSID tonight with the boy for some passenger runs
Not going for gold, I'm going to leave easy with some minor mechanical sympathy
In other news, I have the local tilt tray guys number on speed dial 🤣
  • Like 2
On 27/07/2022 at 8:09 PM, Ben C34 said:
Nice, are you stalling it up or just mashing the pedal?
Often people stall it up and it hinders more than helps. Just mash it and see what happens.
Just mashing and pedalling it
I've still haven't had the RaceTCS fitted yet though, once that is installed it should knock some time off my 60'
Even 2 seconds flat on the 60' should get me into the 11's I'm thinking
The big old girl feels really good
Drag radials will change it, I mean if the 60ft becomes 1.8 you'll be down into the very low 11's to boot.
Then again after you have the slip in your hand you now have extra rims and tyres to stare at going "Ah yeah... cool, now what"
So may as well just do the math and be satisfied 😛
  • Like 1
I'm really happy with the car as it stands, the MPH shows hows that the car is making good power, but with the limiting factor of traction on the dig
I did umm and arr about drag racials, but I cannot really justify purchasing drag radials and rims to get a better ET, which like you said, would just sit a around for most of the time, the old girl was built to be a fun cruiser with some poke, not a drag car
When the RaceTCS gets hooked up I'll have another go and see how that goes IRT improving my traction on launch, my vision is a fast street car than I can drive up and down the coast in, and have a little fun with on the odd occasion, without worrying about needing to swap to drag radials to do it
I am happy to run the R888R rubber on the rear though, so far they are lasting really well, they have run up and down to Goulburn, Canberra, and Coffs Harbour a few times, and are just as good, if not better than the Hankook RS4's in the wet, and they have done alot of driving around in the wet, I'm hoping to get 10-15k km out of a set doing street duties
  • Like 1
Whilst I'm playing around with the car it would be unfair not to play around with the bike
My right heal would get rather toasty sitting next to the exhaust, even though it does have a shield, so, some heat wrap under the sheilding was called for, you cannot even really see it which is nice
I'm riding to Goulburn tomorrow so it should cure well and stop smoking by........ Marulan........
Just need to give the bike a clean, to ensure it rains today, and not tomorrow....
20220731_132203.thumb.jpg.d96d769c21ff5f9967fb389c9b292f93.jpg20220731_132220.thumb.jpg.be14714b5e57b1547ff41028e9742699.jpg
On 31/07/2022 at 2:17 PM, Duncan said:
My tip is....it's bogan cruise ship, not harley, weather down here at the moment mate
I've got alot of warm bike gear that can deal with the cold, and for the wet I've got good wets and warm waterproof boots
I'll will still be on leave next week, and I'm hoping that after hanging out with the daughter for a few days I'll go for an inland adventure, possibly to Walgett, then along the Gwyder into Grafton then the A1 into Coffs, it's a great ride on the bike
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
