It was the little red oil light, that occasionally comes on when it is idling, that talked me into looking into it
Meh, playing cars is fun, spending money is fun
Engine might get refreshed next year.....🤔
  • Sad 1
Needs more twin turbos, also will act as mufflers.
Car will make good noises, less push rod LS noises and whoosy noises. Public (me included) will like more quiet and whoohy Commodore.
I've had a few turbo cars over the years, all made mandatory choo choo noises, but never a supercharged car, now I do
Frankly, the power delivery of this kills every turbo car I have ever owned, it makes about the same Hp as my old 25/30 in the boat, but, pisses all over it from idle
Power wise it delivers better than anything I have ever owned
I actually prefer the V8 throaty roar and blower whine over the choo choo noises from any of my turbo cars
As for the public, all I get is thumbs up and comments about how good it sounds
If we ever meet up feel free to have a drive and give it a little boot, that way you can make up your own mind, I'm as biased as 10 biased things
  • Like 1
On 12/08/2022 at 4:32 PM, Kinkstaah said:
These are really great concise videos tbh!
(I also have a melling pump)
Which one do you use?
Your bottom end is still standard isn't it?
My bottom end was rebuilt... so I think it's standard? Or refreshed.. standard? I didn't do it - I bought it with a lot of receipts but it has new bearings, new pump and was re-assembled. Apparently I have the standard flow, standard pressure pump. I did notice the oil pressure for a LS at idle is quite low, but not critically bad, I am happy that it's at about 28psi now (that my gauges work/don't leak).
I would have probably specced the high pressure one, but I'll admit my ignorance after making my other post, I don't see how the pressure spring changes things. Given the pressure is a resistance to flow... high flow should also = high pressure, and your oil pump specifications should be dictated by how the engine is built (hence the sincere thankyou video man)
The springs just lets the valve bleed off pressure/oil and it bypasses the feed gallery and heads back to where the pickup feed is
On the LS the oil gets the the bearings...eventually
This vid explains the OEM pump well IRT the pressure release valve and how the bypass works
The oil pressure light coming on intamitantly could just be a sticky valve, but, why pull something apart and not put something better in
I believe the low oil pressure light comes on somewhere between 5-10 psi
Well will stick a gauge in after the installation to see what difference it makes at hot idle and higher RPM, and by high RPM I mean 6300 RPM.....LOL
Haha likewise, take my shit box for a spin and maybe you'll end up wanting a R33 shit box again lol...
On 17/08/2022 at 2:41 PM, GTSBoy said:
Nek minit - LS pulled out, RB2530 transplant.
Nope, been there, done that, never again 🤯
The old girl is only at 145,000km, the engine is basically only just run in 👍
  • Like 1
On 19/08/2022 at 10:52 AM, robbo_rb180 said:
Almost a full resto, good yout getting little bits done so its more reliable.
When is the next trip out to the drags?
Not sure, I'm in no real hurry, "proof of concept" was the 122 MPH trap speed
In the end it's just a fun street cruiser not a racecar
Found out that the occasional "squealing" from the serpentine belt when I backed off after a big hit wasn't the belt slipping, it was the OEM harmonic balancer trying to spin itself off
LS1's don't have a keyway to pin the balancer to the crank, it isn't needed NA
BUT, "apparently" your meant to pin them when you build a engine and fit a supercharger, to stop this from happening
My fancy new balancer and crank has now been pinned so they play nice together
Hooray for preventative maintenance
  • Like 2
On 24/08/2022 at 9:45 AM, Duncan said:
ouch. harrop probably should have mentioned if that is a thing...
AI had a look at the Harrop site
Apparently it is an optional extra for "added security"
Meh, it's sorted now
Got bored at work, went for a cruise for a few hours around Sydney, car is a dream to drive, literally flys under the radar, did get stuck in peak hour though for a while, big comfy seats and the slush box makes it a pleasure to drive, pumped some old PIL (Public Image Limited) on the head unit and just enjoyed life, ended up eventually getting some free air when a noisy, fart tuned C63 AMG something something sedan pulled up and tried it on, at "WSID" LOL, nope, Bogans 1, Euros 0
The Bogan cruise ship is so unassuming
My problem now is when I picked up the car, Spiro from Autotech he got out his Moroso calculator, done some sliding around with it and said some Mickey T drag radials should get me a easy high 10 at around 128mph
I would need to drop my current 2.4 60' to around a 1.6 though
So, can I justify getting some 275/40 17 drag radials when the R888R's are worn out??????? Can I ????? Really ????? Can I ??????
YOLO
I'm now looking at another set of of Gold 17 x 9.5 FR1's for street duties with some 255/40 17 Toyo Proxes T1 sports, mainly for daily duties and long weekend trips away up and down the coast, and sticking some 275/40 17 Mickey Thompson ET Street S/S on my current set for "fun" in the sun
Yeah yeah, I know......
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
