On 25/08/2022 at 10:47 AM, Kinkstaah said:
Also if you're gonna do that, buying new rims, go 15's or something for more sidewall.
I want matching rims front and rear though, so throwing some DR on my current set is where its at
The smallest the FR1 go is 17"
Unless I go for a totally different set for front and rear, which I don't, because the FR1 meet my bogan prerequisites of wheels
I did look at some 15 x 8 and 15 x 10 rims, but the rims cost a fortune and look way to drag racer for my " it's basically stock" look that I'm going for
On 25/08/2022 at 2:07 PM, Duncan said:
nothing could be more bogan mate, steelies on the back
Yeah, I did try some custom steel "chasers" all round for a while, but ended up hating them and put the stockers back on, gave them to my mate used them on his box trailer 🤣
I do have a set of 15 x 7 "chasers" in the shed, they can fit up to a 255 drag radial, but, I would only run them at the drags, running them daily would be way too "lower class" Bogan and my family wouldn't let me in the door
My family likes to consider ourselves "middle to upperclass" Bogans, hence matching Gold Simmons FR1's or bust
I'd be running the 15s with 255 et street as more side wall. The smaller side wall 17s will really require a softer spring to get it to work properly.
Chuck them on when heading out to the drags and or throw in the boot with a floor jack and change there.
If really wanting a lower 60 ft thats the easiest option.
  • Like 2
Yeah, but I don't want to run them just for the drags, I want to run them during fair weather short cruises, <100km
The only time I would run the "street tyres" would be during wet weather, or long trips away, like down to Goulburn, or interstate for holidays
Having power without traction defeats the purpose of having the power
The Toyo R888R are better than the RS4's, but, it could be better
I'm happy to replace the Drag Radials when required, I should probably get around a year out of a set if I'm using daily tyres for the long drives, the Harley gets used for short trips to and from work
In the end if I get a 11 something I'll be happy, but having traction on the street is also rather handy when push comes to shove
The 255 RS4's didn't cut the mustard
The R888R are better, but.....
No road tyre is worth it. No 17in drag radial will compete with a 15 one with more sidewall. Just wear different rims front rear at the drags. There's the reason everyone does it. Driving on the road with drag radials is shit anyway, unless you are doing massive launches at every stop, they are really only good for launches, and detrimental everywhere else. Going on a cruise with corners in it I would really advise against running a DR on the rear and a regular tyre at the front.
  • Like 2
Don't you have the race logic traction control now? So should be good for traction
We change wheels and tyres for the road section on road trip stuff. Radials aren't fun on long drives.
If you don't have miss matched wheels are you even drive a commoodore?
I get the whole it looks same wheel setup have a go with the 17s and traction control setup should be a big difference.
  • Like 1
Haven't had the RaceTCS hooked up yet, it has been sitting at Autotech because Spiro wanted to do some research first as he hasn't used one yet, apparently he contacted a mate from Haltech, who knows of the RaceTCS and actually rates it
It will probably go in to get fitted in a few months time
And whilst it's good for traction, it pulls cylinders to do it, with better tyres it won't be so aggressive
I drive the VX like it was meant to be driven, it's is a big fat boat for eating miles, which was never designed to go fast around a corner
The whole point of it is to be a cruiser, that will go fast, in a straight line, not a track car or even playing touge with the kids
My driving style is typically cruising in the left lane with the radio on loving life, only with the occasional roll on, or trip to the drags for some fun
As for daily driving with drag radials, on my old R33 I ran R32 GTR 16" Rims with 255/50 16 MT SS drag radials on the rear alot around town, they were fine in the dry as long as you ran at least 35 psi in them, again, not playing touge or race car driver on the street, just cruising around and rolling it on
Memories
  • Like 2
Booked car in to swap out my 2.5" Y pipe and 3.5" single for a 3" Y pipe and 4" single because........noise
I'm justifying it to my myself because rule of thumb math has it not being a restriction under 650 hp at the fly
So I would be irresponsible not to do it
  • Like 1
Sounds more like future proofing for more displacement 😁
How big were your headers again?
On 8/29/2022 at 2:44 PM, Kinkstaah said:
Is the car not loud enough already or
What did you say??
  • Like 1
What did you say??
What?
Speak up!
1 7/8" to 3" flange
Flange...LOL
  • Haha 1
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
