40 minutes ago, admS15 said:
f**k man, you have a real sickness. Et streets on 16's or even 15's will grip much betterer. Need that side wall big profile energy. Not sure if will look more or less bogan though.
I'm going 17" because I want to have matching rims, and 17" was the smallest size the FR1's come in, so comprises were made for the Bogan-ness of the FR1 life, it isn't optimal, but meh, it's going to be good enough for what I want
My old GTS-t Skyline made similar top end power to the Commodore, and got a 11.09 on ancient worn out 255/50 16 Mickey Thompson streets, and they hooked pretty good on the street in the dry as well, which is handy with a RWD car
Plus the Mrs will never pick the change, which is always a bonus
As for looking more or less bogan, impossible, the car is a old red commodore with gold FR1 Simmons, and I'm a old balding white guy with tattoos, so  I'm pretty sure I got bogan covered, much to my Mrs anguish
  • Haha 2
I has rubbers, build date was 0822, fresh stock, which is nice
Ordered the rims, they're getting machined for offset, I pick them up and get the tyres fitted tomorrow
Typically it has started to rain again so Wednesday night drags probably isn't on the cards
  • Like 2
Almost the ultimate bogan chariot but needs 2 doors for that title.
Get onto a suspension shop about a decent rear setup. That tyre can work with the right setup.
4l80 or 6l80 an option for you? t400 is getting hard to find now and decent internals
https://www.facebook.com/BrinksPerformance/posts/624930669420914
My current suspension will do for the 2 or 3 trips to the drags I do a year, the car is just a street cruiser with visions of grandeur
My old R33 only ever ran Bilsteins and kings and hooked OK on the Mickeys
As for the gearbox, there's a few options, but really, unless/until the 4l60e goes bang in a big way there's no hurry
Currently the trans is rated/guaranteed to 600hp at the motor, which it is roughly at now, Craigs have stated that it will still be fine though as they add in a fudge factor, they said it should be good for about 700hp, or 450kwatw but, that would void warranty and be on limited time
Fark, I keep blowing the main 60 amp fusible link
No reds at all, I just parked the car after returning from a drive, then tried to move it to wash off some dirt and nothing, no power at the ignition, no reds, no horn, no central locking,  no immobiliser, found the main 60 amp fusible link blown, so replaced it with the 60 amp ABS one to see what was going on, which brought the reds up, until I tried to start it, which then blew that fuse as well 😒
There's a short somewhere, I'll  need to jack up the car and look for the short, I'm hoping it's an easy "starter motor wiring meets exhaust headers" type of thing
Stupid cars 🚗 😒 🙄 😑 😤 😐 🤣
  • Sad 1
That sucks, I guess she doesn't want you to put those new tyres on her
FWIW, it won't be the starter motor via a 60A fuse, way too small, but headers (and anything else you've modified, which is almost everything now :p) would be the place to start.
Multimeter in the Fuse socket will probably confirm continuity to ground, and one option is to disconnect battery +, put 60A fuse back in and then check the regular fuses one by one to narrow down which specific circuit has the issue (I'm assuming the 60A fuse is in serial with the individual fuses like in sykline)
Yeah, but if it's enough current to pop the 60A fuse, it really shouldn't blow one of the smaller fuses downstream. I would presume that there's a significant short in the wiring between the 60A fuse and any other fuses downstream. Melted insulation is the obvious thing to look for.
But yes, pulling any and all downstream fuses, then probing in the 60A fuse socket looking for earth would be the best way to start. Hot tip - there shouldn't be a nice path to earth there!
1 hour ago, Duncan said:
It never ends
But it is expected with old or modified stuff
And it's not like it spends it's time in a garage coming out on sunny Sundays, the car is regularly used and abused, rain, hail or shine...well, rain and shine, I always keep an eye on the BOM for work, the car and bike is typically hidden away during major storms
I expect things to happen, nothing lasts forever,  and shit breaks when you lean on them, but, I'm happy enough because the old girl gives alot of joy, the car is fun as well..............😜
As for the new starter, I've still got some heat sheild left over from the job I did on the headers, I might look at making a cover like this thing > DCI-XT-5000-STR.thumb.jpg.836ec6b8b1a907e4a6410811e19de383.jpg
  • Like 1
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
