Hi, I just had my 25 neo tuned today on a apexi power fc.
The engine is stock except for 3"exhaust all the way and blitz fmic. I have a turbosmart manual boost controller, set at 10psi.
But after 4500rpm, the boost won't hold and lowers to 7psi at higher rpms.
Is it time to start searching for boost leaks? Or is there something I'm missing?
Thnx. Jasper
https://www.sau.com.au/forums/topic/480086-rb25det-boost-wont-hold/
I deleted the 2 stage boost solenoid. Incoming line to the turbosmart boost T comes from the turbo, and outgoing goes to the wastegate actuator.
Anyone else using only a manual boost controller and running 10+ psi?
I think something is not right, it should hold boost
You didn't mention the bleed - you do have the right one going to the actuator?
To test properly for boost leaks you need to make up a plug and put about 20 psi into it. Leaks are sometimes hidden from sight and hard to hear with the motor running.
3 hours ago, Jasper34gtt said:
The T only has one input and one output... In comes from turbo, out goes to wg actuator.
I think that's correct
OK so it bleeds to atmosphere. Is it supplied from a nipple in the compressor housing? Have you tried turning up the boost? I see the turbosmart instructions suggest removing the ball and spring in some applications - have you tried that?
Using the cold charge pipe as feed instead of directly from the turbo housing, shouldn't matter I think. But I'll try
From the compressor housing yes. I tried turning it up and stopped at 11psi. Then after 4500rpm it goes back to 7psi for some reason. I will try your suggestion to remove the ball and spring. Thanks
1 hour ago, Jasper34gtt said:
Just a thought... Could it be that the stock cat is too restrictive and exhaust gas pressure is pushing the wastegate flap back shut?
It could be blocked too. Either way I would either lose it altogether or get a better flowing one. If you can without outraging the neighbours  you could try dropping the exhaust altogether to see if that is where the problem lies.
Also, if dropping the ball and spring doesn't help you could pull the hose right off and , driving carefully so as not to overboost , see if the problem is with the wastegate.
But you would be very very wrong.
There is enough pressure drop across the shitty sidemount for that to be a bad idea. Although it should result in other bad effects, not low boost.
I'd seriously be looking for boost & exhaust leaks.
Look you should drop the cat as Kiwi said just to eliminate that as a cause, but it probably isn't. I've had completely blocked cats. The side effect generally is it is pathetically gradual to build to peak boost, makes jack power everywhere, but the peak boost is still usually up the rev range. Blocked cats generally do not cause a spike to peak boost then drop like you are explaining.
I think the problem is elsewhere, but do it just to check anyway.
Ok I will check the cat.
And as for boost coming from hot or cold pipe, I just installed it exactly the way turbosmart advised.
People do have good boost over the complete rev range with just a manual boost controller? Or do most people install a rb20 actuator? I thought I might give that a try... Maybe the wg spring is just too weak
22 hours ago, KiwiRS4T said:
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
