Hey guys,
Just bought a R33 today and I've never had such a hard time driving a car. The drive itself is fine, feels super healthy, but the clutch is super aggressive. It has a OS Giken of some sort according to previous owner. The issue I'm having is that it engages almost at the top of the pedal and it's instant. Seems like there 1-2cm of distance between full engagement and disengagement.
Is there anything I can do about that? I've been driving manuals for 10+ years and I stalled this car 30-35 times today at red lights.
https://www.sau.com.au/forums/topic/480135-r33-clutch-engagement/
Check it is bled properly.
On a different car I moved the pivot point and ussed an adjustable rod to get the take up point where I wanted it and a wider range of modulation, so there are things you can do, but it will never drive like a stock clutch.
Ok, as long as I can get a bit more modulation out of it I'll be happy. If the revs aren't high enough there's no saving it when it starts to stall. I'll check it out tomorrow and see what it seems to be, was too dark by the time I made it home.
unfortunately with this sort of clutch you have to be aggressive with them, meaning you have to get the revs up or you will stall it every time.i have the same problem with mine as they get warmer they grab instantly. but I had no option as I was needing something to handle lots of grunt,i am use to it now but you get a few funny looks from some people as you take off.
As said above. You'll not get any more modulation out of it unless there is some left at the top of the travel, in which case it will be eating itself as you drive it now. All you'll be able to do is move the takeup point somewhere else.
Yeah, I'm feeling much better about it now. Found some hills out in the country this morning and practiced for a bit. I almost always get it now and if it feels like I'm not giving her enough I just let the tires bark. Thanks!
Good to see you persisted and now you're getting the handle of it, now you get my last comment I chirp the wheels all the time just to get the thing moving, on the flat its fine but once you take off on a incline its more challenging, great to see you didn't bag the clutch its just what it is.mines a ceramic clutch which can handle a lot more heat, I use mine down the strip so I needed something to handle the launches.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
