Here's what I use on the 32 and 33 gtr. Supercharge MF40B20L Goldplus series is a good choice if you want to keep the standard size. I have to use a 40 in the 32 as I have too much shit around that area to run anything bigger. In my 33 it's a 55. The MF40B20L is 390cca and compact, this is the standard physical size for 32 and 33 GTR. The Century MF40 version by comparison is 330cca. MF55B24L is a better choice as they are 490cca, but they are wider. These seem to be my picks as they best available under $200.
After that you go all out with the Optima AGM Yellow tops. By far the best, but approaching $400. They are available at 700cca plus and people have reports of batteries lasting 7 years or more. I don't see the point as Supercharge Gold plus is 40 months no questions asked replacement warranty.
The MF40 is the standard factory size and MF55 is actually the Nissan cold weather pack upgrade size, hence why you can fit both. Same depth and height, just a 55 is wider as mentioned above. So if you can run at least a 55.
More importantly than any battery though is get a Ctek, especially if it is not a daily driven car, which is most GTRs. Need a good maintain charger.
  • Like 1
@GTSBoyIs that true - as in outright replacement, or is it just the pro-rata
Complete replacement, as in within 40 months of purchase if it fails, full new battery on Gold Plus series. My old man even did one literally at about 39 months from purchase recently on the XR6. I can say I have done it about 3 times across all of my car's ever. The dealer stamps it on purchase, and they are very adamant about retaining and supplying your original receipt upon replacement, but apart from that, yeah no problemo. Sometimes they'll want it overnight to prove it, but if it is stuffed its stuffed and they'll see that.
Cool, you realise that it is the right positive terminal instead of the left, which is standard in a GTR ? It does have the correct small terminals though.
CCA is also 450 on a 38ah battery.
Does not sound like good value unless it does last you at least 5 -  6 years, as that is the price of 2 x MF55B24 with 490cca and 50ah. I am yet to justify the price of Optima. Happened to have this in the ute for reference:
There is absolutely no question they are good, all the serious 4WD and off roader guys run them here. I just couldn't justify $300+ for 38ah and 450cca.
Post back in 5 years and see if it's still going strong ?
You really don't get what I'm saying do you ? 38ah is the smallest, most piss weak size battery for any car, regardless if it is a $100 or $1000 battery. As I said above 50 minimum is generally the go for any car now, and paying that much for such a small battery just seems silly. Anyway sounds like you went and got one so hope it lasts ok.
When people have been going through the trouble of going to an Optima yellow top they go for the big ones and make them fit for a massive increase in CCA and AH, or to mount them laying down as they are AGM.
  • Like 1
On 01/06/2020 at 3:58 PM, GTSBoy said:
NS70MF
650 CCA.
This is essentially the physically largest and largest capacity battery you can drop into the stock location.
Hey if this is in your 32 , next time you need a battery the Supercharge Goldplus equivalent is the MF80D26. Same dimensions but 80AH and 720cca ?
  • 1 month later...
Just an update, took your advice bk and went the supercharge gold plus? Starts awesome and very reasonable price. Went the 55B24.
Hey Ben,
Awesome insight into the topic.
Quick question, what would be involved with swapping over to Optima Yellow?
  • 2 years later...
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
