All,
I have painted over years but with minimal knowledge so I am trying to up my knowledge.
here are my qestions:
paint procedure is as follow with points needed to be done on each stage, is that correct ?
1. Primer( if bare metal) or grit 1500 to create area for paint to stick if there is already paint. This will be 1 to 2 coat. one needs to wait 24 hours before going from primer to sanding to doing base coat.
2.Base coat, 2 to 3 coat. some say 4 to 5 coat which ?
Waiting around 15 mins after each coat.
3. top coat, I don't really understand what this is, what is the top layer?
4.laccuqer or clear coat , 3 to 4 coat. around 15 to 20 mins after each coat
5.polish
temperature is what is I have in garage which is around 15 to 20 degree.
I have painted a metalic car using above and paint is sort of matt , is there specific laquer to be used with metallic?
https://www.sau.com.au/forums/topic/480620-few-general-questions/
After the first coat you give it a sand and hollows etc will show up  for you to fill. Top coat is the last coat. Laquer is for show cars...shows up every deficiency in the metal.  Requires many coats. Enamel is easier and more forgiving.
8 hours ago, drifter17a said:
When you say sand with 600?
would you fill hollow with bonding compound or next layer of paint
Depends on how deep the hollows - there is a special spray on stuff you can apply locally.  Have done some painting but I'm no expert ...have a look at the pros on YouTube.  Also you can get free advice from the auto paint shops.
On 17/06/2020 at 3:29 AM, drifter17a said:
All,
5.polish
hi mate,
some paints require a Ground Coat which is usually the metallic colours. just double check if you need this or not.
I wouldn't fill the minor scratches with bog.. just use primer filler or a spray putty.
just to make it clear. will you be using acrylic paint or twopac? I would not recommend using two pac paint in a garage as you need a proper booth. with acrylic you can get away spraying your car in your garage and depending on the coverage I would personally put on 3-5 coats and 3-4 coats of clear on top.
Also, with acrylic paint, you need to wait for to paint to cure for couple of days, wet sand and and cut and polish after.
Thanks bud
would ground coat be same as the first wet laquer before base coat, seen that on youtube and didn't understand it
when you donbase coat, i was 15 mins between coats and after 30 mins following last coat do laquer or clear coat otherwise as I understand you need to sand it with 1000 to create but surface if doing it say next day
re paint types, i know mine is metallic but don’t really know different type of paint and whether mine is acrylic
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
