Faulty boot release.-
Hi all,
I'm in the uk and thought i would try you boys in Australia for some help as my 2004 skyline 350gt is a rare car here in the uk.-
My boot release.- doesn't work by using the remote or switch on the dash
'I'm been thought my G35 disc and the Haynes manual and have worked out the Body Control unit sends a positive fed to boot lock to unlock. Also the dash release switch connects to earth and when pressed sends negative to the BCU to tell it to open boot. When i press the boot release on the remote i can hear a click from steering wheel area so i know it's receiving the signal ok.
My problem is the G35 isn't the same then it comes to wiring colours/position of pins in plugs and the boot release isn't in Haynes. I've rechecked all cables which fed into the boot ( i replaced every cable last year) and all fine. I have checked every wire one by one which connects to the BCU for the positive unlock boot fed when i press the remote and dash switches and nothing! I have also checked every wire for a negative fed from dash switch and again nothing.
So i thinking the BCU is faulty!
Any one have correct wiring details for a import? Any other ideas?
Thanks
  • Thanks 1
https://www.sau.com.au/forums/topic/480761-boot-release-problems/
38 minutes ago, 57jam said:
Oh shit, how are you going to get in the boot!
Fingers crossed we get some replys.
Tell me about it, not good, I was thinking about wot u said n wen u said u run a positive from Battery to the lock it works, so my question is how do I do that ? "Run a positive" wots that, wot to use ? N where about on the lock do u attach it ?
I didn't no u could do that but I'll give it a go that's for sure, if u can help me 57jam of cause.
Eager to hear back from u cheers brother.
It's basic electrics, so any auto electrician whose workshop doesn't look like a barnyard will be fine, I'm sure. Definitely the safest thing to do because if you don't understand low voltage electrics at a basic level, you could end up doing way more damage than just a snapped steel release cable.
There's no dark art to these things. It's button, solenoid, wiring or BCM. In 57jam's case, he seems to have ruled out wiring, buttons and solenoid. That's not a promising sign from a cost point of view.
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
