On 12/10/2022 at 6:05 PM, robbo_rb180 said:
Good to hear, I was planning on mounting a baton light off the wall to light up engine bays. Maybe even a bracket to angle down a bit.
Hey, Rob, just to clear up the light purchase, I didn't buy them from HN, I bought them on ebay, way cheaper.
I was thinking of buying some led strip lights and mounting them on the link between the hoist's uprights, just an idea in my head at the moment.
I
  • Like 1
  • 2 months later...
I
Thinking through this, I think you might find light on the uprights annoying to work with as when you're under the car looking up, you're going to potentially have bright light shining into your peripheral making it harder to see up under the car in specific circumstances.
It may be different for others, but I find I can typically see better in my garage if I close my roller door, as the light coming in the door is from a focused point, if that point is partly shining through somewhere I'm trying to look at, I can't see the darker area. IE, looking down through my engine bay, but light is shining from the floor up. I kind of liken what happens to me like when you're trying to take a photo of something dark, but there's a bright light source in the frame as well.
For use when working under the car, it might be better to have lights along the floor, shining upwards from each side so the light is "behind you" at all times, rather than potentially level with.
I've also found in the last year, the head mounted torches and be a real blessing when using a hoist.
Very true Matt, I've tried cable tieing inspection lights to the uprights and the legs, that doesn't work, actually it makes it worse as all you get is blinded eyes.
I stole Melinda's head lamp like you said, but it annoyed me, so when we go into town next, I think I'll go to Jaycar and ask the expert in there, best thing about country towns, you get to talk to the same person all the time.
Cheers for the advice Matt
Neil.
  • 1 month later...
So, here's an update, this summer has been way worse than the last few and things are heating up. I get sun on the roller doors for all of the morning till about 1pm. I can open the doors but basically the heat sits in the roof cavity and has nowhere to go, remembering I have pool noodles blocking any escape. The air cond is tragic, it's too small and can't keep up. So after talking to my awesome back neibour over lots of beers he tells me he has 2 spare whirly fans he doesn't need and he's after another 30m hose reel which I have and these conversations were hours apart, so after 4 hours of drinking we decided to swap. Now I have to get up the courage to go up the big ladder and install them in the heat, hope I don't fall, wish me luck, this frightens me.
Be careful up there Molly! (surely not too soon).
In any case, I'm not convinced those wind driven ones do much, I guess it is worth the try. I've got Mark's awesome solar ones in the garage (not the shed sadly) but they aren't available any more and I think most current ones are junk too
I bet we get a full review by mid next summer on how well they work, and if the shit job of getting on the roof is worth it!
I'm quite intrigued on if they will do anything, I've never really looked into it.
That said Neil, for you sun issue, I have seen some super promising stuff on a paint you can make up, and your surface temps end up BELOW ambient air temp! Some really funky physics going on in it!
Lastly, while you're on your ladder, can swap the tubes in my lights in the garage, and plug the third bay in for me? I hate ladders just as much as you do! So far... I'm still working with less than ideal light :P
I was of the same thinking as you, 2 problems poped up though, the best warranty I could find was 2 years and none have any battery charging/backup, so they stop when the sun goes down. Not going to cut holes in the roof for shitty solar. I have been checking out the normal ones and with no wind to turn them, the hot air rising keeps them spinning, so I'm going with them.
Yea buddy time will tell, my god the roof gets hot!!!. Thinking it will be an early morning exercise.
There is no way in the world I'm going to sit up there on the roof and paint it, you're crazy.
I didn't even mount the power points in the ceiling, so let's stick with no.
  • Haha 1
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
