So this is my first ever write up and unfortunately I didn’t take very many progress pictures but I will try my best to explain the process with some picture aids ??
Materials:
* plastic floor trim 96in x 6in x 5/16 (x2) you can get these at Lowe’s or Home Depot
* 3 inch L brackets (x8) Found at Lowe’s
* Self tapping screws ( to mount brackets to car)
* Hardware to mount bracket to skirt extensions ( I used black license plate hardware with plastic backings x16)
Tools: Grinder, drill, something to cut the plastic trim with.
Process:
So for a sedan with stock type M skirts the overall length is 73 inches (coupes might be different I suggest measuring before cutting). After this you want to get the skirt extension as level as you can between the front and rear low points to do this I used various objects like toolboxes and children’s books
I started with measuring out the two brackets that would be in the center of the skirt, I measured from the top of the pinch weld to the bottom of the skirt extension. If i remember correctly it was roughly 1.25-1.5 inches, always cut bigger than you think as you can grind down the bracket until you have a perfect fit.
The end result would be for the top of the bracket to be flush with the top of the pinch weld, Once you have the bracket cut to the right spot and the bottom arm of the bracket gently rests against the skirt with the various objects keeping the skirt level then you mark the hole with a sharpie and install the bracket. Once you have the two center brackets installed to the car you can drive some temp screws through the bottom of the skirt extension to hold it in place as well as Mark the holes for the permanent hardware. Now it’s time to work on the ends, these are a little more complex to line up and install as you have to more aware of the jacking locations.
Front7646F151-E3AA-42D3-98D1-D09530975645.thumb.jpeg.cbde9c562985357f66da0d4add45cd21.jpeg
Rear57AF7906-03A8-452D-B064-84A65DA2FBDB.thumb.jpeg.164c52288f3eb3f4699c1ad7b7972622.jpeg
For the front I had to turn my steering wheel to gain access to inside of the wheel well and feel for a flush surface to mount the bracket to, as i held the bracket against the surface and lined it up with the bottom of the skirt extension i used a sharpie to mark the hole and kinda outline the bracket so i had a general idea of where to drill once I jacked the car up and got under it. If you’re pretty coordinated you could probably just blindly full send a screw through the hole. Same concept applied to the rear. Just make sure you have plenty of space between the bracket and the jack pad as you will have to trim the inside of the skirt to have room to use the the jack pads. Once the skirt extension is mounted you can mark where you need to cut to allow a floor jack access to the pads. Once the ends are installed drive some temp screws through the bottom of the skirt extension. Or just mark the holes on the bottom with a sharpie to drill later. Now all that’s left is marking the area to cut for the jack pads, uninstall the skirt extension and make the cuts.
Unfortunately my car is too low to use the jack pads without the floor jack arm making contact with the skirt extension, to get around this I either jack up the car from the differential, use the emergency jack, or you could potential use something on the floor jack pad to help it gain elevation before the arm makes contact with the extension.
After i made the cuts i reinstalled everything with the temp screws through the bottom of the skirt extension and made sure everything was still level. Once I was happy with it I uninstalled everything including the brackets and prepped for paint. At this point I drilled out the holes to accommodate the permanent hardware ( I would try and find something that has a really flush bolt head for a cleaner look) A1EB4A45-12ED-4BFD-B78B-C442862DFC86.thumb.jpeg.cf43445bf9e0a14bffe108c7c521a854.jpeg
Once the extensions and brackets are painted it’s time to install everything, make sure you remember which bracket goes where or you will be making extra adjustments and possibly drilling new holes. To install the hardware through the top you will need to install the brackets to extensions first then install the entire assembly on the car. After the brackets are installed on the extension I would suggest to install the center two brackets first and then work the ends.
I hope this write up helps anyone trying to do this, and if you have any questions send me a pm and I’ll do my best to answer them ??
  • Like 4
https://www.sau.com.au/forums/topic/480938-r32-sedan-skirt-extensions/
On 8/12/2020 at 5:56 PM, Chris D said:
Looks good. I’m thinking about doing this for the R324. I have 8x2 ft section of aluminum that would work well. Dark slide where are you located?
Thanks man, I’m located in Texas
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
