Team Raceworx have obtained some great prices on OBX seats.
Full details are on this webpage:
http://www.hgeconsulting.com.au/raceworx/obx.htm
Prices are from $460 per pair which is about half what you would pay elsewhere! With the money you save you can get BRIDE embriodered on them
Please note seats are sold in pairs only, but if 2 ppl agree on the same seat and colour I can organise that.
Also note the seats do not come with rails, you should allow up to about $200 to buy new ones or have your factory rails modified.
Please post interest in this thread.
https://www.sau.com.au/forums/topic/48101-cheap-obx-race-seats-for-sau/
  • Replies 75
Is that per/rail or for the pair?
yeah I should have been cleared, $200 ea.
So if you go fixed back, you could have 2 news seats, installed from about $1k.
The other option is to go halves with someone else who is interested, if anyone just wants one seat post up here and we will try and match it up.
Are they approved for CAMS events etc? (Scuze my ignorance).
Also where would you get the rails from?
Is there any chance of having a look at the seats? (either through another seller or somewhere that may stock them)
Thanks - they look great too!
Yep, they are CAMS legal if mounted correctly, we have used them in NSW circuit racing and Targa Tas.
As for rails, there's a couple of choices.
INASNT has a group buy going for rail, these seats should be able to bolt on. Alternatively I know Powerplay in Drummoyne sell Bride rails which bolt straight in. Third choice would be to get a workshop to have a look at reusing your standard rails.
Having a look at them, I have the Forza in my race car, and we also had a couple of people buy the Daytona. Apart from that we don't have a any of the other models to have a look at.
Yes i do, check my signature.
They are bride copies (From my original bride rails) and they are not just the rails but the whole seat frame with the drivers side belt buckle which bolts directly to the skyline floor plan, then they you just to slight modifications to to bolt the seat down.
Register your interest in my thread as the first few are getting made today so i can finially put my recaros in.
you can get these seats on www.modyourcar.com for a little cheaper...
actually I'll beleive you'll find our prices are cheaper as they include delivery to capital cities. MYC will slug you an extra $15-20 on top for that.....
i see there are r32 rails.. yay thanks!
thanks for the offer SW20 I am actually interested in the carerra but may take you up on that offer just to check the seat out.
Thanks alot all of you guys appreciate the info!!!!
Nozila, the fixed seats can be a pretty firm fit...great for spirited driving but it might be inconvenient day to day...just depends how much you want a good tight seat :rofl:
I'm pretty interested in the cheap (wide) fixed Daytona in black, or the Monaco. Duncan, What is your opinion of the choices I have selected (which are obviously the cheapest) fitting wise?
These guys in Melb have them so I will go take a look if possible. http://www.australianauto.com.au/
Nozila, we have already made our minimum sales so we can continue to offer these prices whenever you order.
Skylinegeoff, Australianauto are the OBX importers, we resell for them and should be a fiar bit cheaper than going direct :P If they have a showroom you should be able to have a look. We have acually only sold fixed back seats to date so I can't really tell you anything more about the monacos. The Daytona I have seen and they are fine, they can be mounted direct to the floor as we have for our race cars on on rails (eg Bride or INASNT's copies). Personally, since you are in Melb I would go for the copies as they are cheaper and you can check them out locally, in Sydney I'd get the Bride originals from Powerplay as they have them in stock atm. Some cars you can modify the stock rails to suit but apparently that's pretty tricky for a skyline:(
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
