Looking for a little electrical help. I have a hcr32 on a Nistune ecu that at first, had problems with holding connection to the software even with the key only in the on position with the engine off(so not an electical noise issue). Now, I cannot connect to the ecu at all with Nistune, or data scan software. I have tried different cables, different laptops, even re-wired a new consult port in. After that I tired the paper clip jump trick to get codes to flash and nothing worked. I have just got another oem ecu, and still have no luck. I’m quite stuck now and id appreciate any help. Thanks
Edited by smart_garrett
https://www.sau.com.au/forums/topic/481195-no-ecu-working/
19 minutes ago, robbo_rb180 said:
Does the car start and run?
If ecu is not getting power check ECCS relay and associated fuse
If just a communication issue test the continuity of the wiring from the consult port to the ecu
The car starts and runs great. I also tested the wiring from the consult port to ecu and everything was good, even rewired a new port and still no luck.
https://www.sau.com.au/forums/topic/481195-no-ecu-working/#findComment-7940544
ok, double check the continuity/resistance of the consult plug wiring and correct connections at ecu and port.
Have a re-read of this Nistune Diagnostic/Connection issue guide
https://nistune.com/docs/Installation_and_Communication_Diagnostics.pdf
consult port wiring guide
http://nistune.com/docs/MAF_and_Consult_pinouts.pdf
for it to be an issue with the factory ecu in my opinion it is a wiring/pinout issue
https://www.sau.com.au/forums/topic/481195-no-ecu-working/#findComment-7940547
The consult wiring guide is the guide I used to rewire my consult port to a new wiring specialties pig tail. I have 12v and a ground, but I’m not sure what I should be seeing at the Rx, tx, and clk connections, if anything.
https://www.sau.com.au/forums/topic/481195-no-ecu-working/#findComment-7940548
14 hours ago, GTSBoy said:
Nothing that you can see with a multimeter. That's a serial link. You're talking digital data at many kbaud.
That’s what I was thinking that’s why it’s hard to see if it’s receiving or transmitting data.
https://www.sau.com.au/forums/topic/481195-no-ecu-working/#findComment-7940614
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
