Hello, bad news ?
I installed injectors (1000cc top feed) 2-3 weeks ago, All seemed good.
Untill today I did a boost leak test and the injector oring bosses have pushed out....wtf
Before I go and pull it all apart, what do you guys think I've done wrong for this to happen.
Thanks ?
Edited by dyl33
https://www.sau.com.au/forums/topic/481235-injector-o-ring-bosses-pushed-out/
It looks like the fact it could move up the rail is too high.
Need to reduce the length of the spacers, assuming there are spacers.
How much pressure did you apply for the leak test?
@Ben C34 after further inspection i believe thiere is a problem. See pic.20200927_120017.jpg.57000c0be448a6322d8ee8548359a439.jpg
There's a decent gap at the top which would allow it to move up, i think this is the problem. Or am i missing a spacer or somthing?
The injector kit only works with 3/4 height top feed.
I was sold the kit by Kudos motorsport with ev14 1/2 height injectors with height adaptors (short, 14mm)
So im not sure if I've been given the wrong injectors or is there an issue the the injector o-ring bosses or somthing else.
Thanks robbo, yeah maybe I'll have to if there's no other way. but its strange there's a instruction manual to install this fuel rail kit. States 100% bolt on and mentions nothing about shaving spacers down. ?‍♂️?‍♂️
I'll find out more tomorrow hopefully.
Edited by dyl33
I have the taarks kit and it all bolts in nicely - my spacers don't look like that though and i use the injectors that came with the kit, bosch 960cc
Thanks @hardsteppa yeah I reckon Kudos has made a mistake. It should work 100%. Are you able to get a pic of you spacers/rail?
Edited by dyl33
also i remember during the install; the bosses pushed in but then some popped back again again like yours is in your pic. Had to push them back in slowly (taarks note this in their instructions) for it to slide in and stay in; not any further issues other than that though.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
