So my rb26 has an issue where it ate up two valves, damaged piston and bore and damaged head chamber. Anyways I need to figure out what to do. I have a full set of darton sleeves and was thinking of using them and wanted to know what everyone’s thought is on running them. Also my head is Cnc ported and was thinking of welding chamber up and digitizing a clean chamber and milling it out at work. What’s your thoughts.
Thanks
Richard
Edited by ricardo.benin
https://www.sau.com.au/forums/topic/481377-need-help-on-rb26-build/
Send head to head shop. It probably isn't as simple as "digitsing, welding up and copying". The broad shape of the chamber can probably be done like that but any damage around the valve seats probably can't be fixed that way, and it would need to go to the shop anyway. Might as well just skip the geek-fest fun part of it and get the whole lot done by someone who's done it before.
I like the sound of where you work! How did you bend valves, some sort of timing/timing belt issue?
Other than getting too large (ie if it was already 87mm), I would definitely bore the block out and reuse the current sleeves. Of course the liners can be replaced but that is a lot of precision work when a bore would do the job (noting, depending on access to equipment that may not be too expensive for you). The bores (when measured/machined correctly) are not a problem point on RBs
Re the head...normally you would get a fresh bare head because they aren't that expensive, even brand new, but again, if you have the tools and knowhow, welding and remachining may be an option.
Appreciate it, the head was welded by one of the best aluminum welders is the states for head and block welding. And I think what happened is I must of got valve float or something along those lines. When I bought the car the seller said car is ready to make serious power which it wasn’t, had a rebuilt short block with tomei pistons and a Cnc ported head. and stock everything else, so not sure what was going on in the sellers head but it was my fault for taking his word. I bought mahle pistons, darton sleeves, oil pump drive kit to fix the oil gear, and carillos top of the line rods with there super rod bolts that are supposed to be better than arp. Still not sure on what springs and retainers to run. I’m not sure if I want to run a dual springs because of the added seat pressure and valve train wear.
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
