Hi everyone,
I hope everyone is having a good day as a skyline owner ( or enthusiast)
I am having a very difficult time with my cluster at the moment. Here are a list of sections to my predicament:
- None of the gauges work (except the turbo gauge I think)
- The lights on the cluster will light up (handbrake light, check engine, battery etc. when I stall) but are not on regularly
- I have sent the cluster to a specialist in the Eastern Melbourne suburbs. He took it all apart and said he could not see any issues with it
- I have sent the car to the Auto Electricians in the Eastern Melbourne suburbs too, they had a look at the wiring and said they could not find anything wrong either
- The car does not have a Speed Transducer in the car at the moment. I have bought one but have not yet fitted it.
This leads to my questions.
If I replace the speed transducer, will this fix the rest of the issues on the cluster? I was hoping that it maybe completed some form of a circuit for everything?
Could it be the ECU? as far as I know I am still running the stock ECU
https://www.sau.com.au/forums/topic/481595-r33-gts-t-cluster-issues/
So the auto electrician says the wiring is ok ? Yes ?
That was their exact words ?
 And the "cluster specialist" said that all the instruments were working ? Yes ?
Again exact words ?
Then my money is on the flexible plastic circuit board sheet on the back of the cluster.
It may well have some breaks in it.
Can you change out the entire cluster ?
Hi @PLYNX
They did, they both said they could not see any issues with either the wiring or the cluster. The Cluster guy took it all apart and had no issues with it. The Auto Elecs tested the wiring and said they couldn't find any issues.
That is a good option, I hopefully can find one to buy in Melbourne. Have you heard of this issue before or just an educated guess?
Thank you regardless mate it is much appreciated
Yep had something similar happen to my R33 but not to the extent of problem with yours.
Changed it out, to test it, and it worked fine and then went over to a Veilside cluster and had a instrument repair place change the kms to the same as my original one( had to sign paper work for them )
Only other time I've seen a similar thing is a NISMO 300km/h cluster fitted to a manual that came out of a auto.
Fitted up It wouldn't work properly on the manual and when re-fitted to the auto worked fine again
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
