Hello. I have recently bought an RB25. It claimed to have poncams but no specs were available. Removed covers to find both intake and exhaust are 264/264 with 8.5mm lift.
Looking to degree the cams- but I can't find any info on a 264 intake and exhaust.
Are these real cams? Or knockoff? Never heard of fake camshafts but there is fake turbos so it's arguably easier to fake cams...
Cheers!6B0C81AD-4D30-45C5-B6DB-3DDDF8131D69.thumb.jpeg.6ca6daeb767c5dfae92fb0ae3b8da4ec.jpeg
https://www.sau.com.au/forums/topic/481662-fake-poncams/
1 hour ago, r32-25t said:
He retired last week or the week before
Really ? That sucks, they had some really good grind selections. Only just sold some new Camtech RB26 cams last week for $500. 🤦‍♂️
Kelfords only now I guess ?
https://www.sau.com.au/forums/topic/481662-fake-poncams/#findComment-7944615
Just now, CLEM0 said:
They certainly don't seem current- but I can't find any specs to degree them in!
Just put them on the same LSAs as any other 264° cam, or choose an LSA halfway between the typical 256° and 272° cams' specs. Tighten or widen the LSA by a degree or two depending on how you want the engine to work.
https://www.sau.com.au/forums/topic/481662-fake-poncams/#findComment-7944623
Ages ago I was told that Tomei cams don't need to be dialled in and should always be set to zero ...for RB25 Gtst's.
This was after we dialled in [from memory 5 degrees [could have been 10, it was 20 years ago]] and it ran like shit.  Asking around everyone said to set to zero and it will work.....we did, and it did.
I could be wrong for your motor, but if you don't see gains then zero is your answer.
But Dose Pipe and GTSboy will know more.
https://www.sau.com.au/forums/topic/481662-fake-poncams/#findComment-7944624
Yeah I heard that too- but these seem fairly big for what most run. Probably going to get some stock cams for now- runs like a dog off boost and isn't fun, 120psi across all 6, shitty idle etc
Likely they are 0* right now- no adjustable cam gears so I think for street use stock is fine.
https://www.sau.com.au/forums/topic/481662-fake-poncams/#findComment-7944626
  • 1 month later...
    • 12+ months passed so they have no obligation to do a warranty claim. It leaked from the rear circuit. Front circuit was fine, but I tried many times to bench-bleed and in-car bleed (wasted 1L of Penrite racing brake fluid) to no avail. Threw my old BM50 or whatever the standard R32 GT-R BMC is, brakes went back to normal. So from my very limited anecdotal experience, I cannot recommend HFM, even though a lot of their products looks good. Just my experience (I have a genuine Nissan BM57 in a box waiting to be installed now).
    • How dare you sell your unreliable Skyline and buy a reliable, Toyota/Yamaha car with a strong gearbox, torsen LSD and Toyota reliability. At least you won't need to worry about oil pumps, big catch can, oil restrictors, blowing off power steering belts, sheering off 3rd gear, failing ABS relays/pumps, etc.
