On 05/06/2025 at 10:45 AM, V35_Paul said:
Yeah I have the same mods but no heat exchange too. Had my local exhaust guy fix the the awful sound it makes when you put on downpipes or High Flow Cats.
I'm looking at a tune too but I'm thinking getting a LSD first.
I got some Michelin pilot Sport 4s but that was a long time ago and need a new set soon.
Tyres, Tune, Heat exchange and LSD. Money money money 💰 💰 💰
Mate , I have the same issue right now with the exhaust noise , if you can tell me what your local guy did , I'll talk to my guys and see if they can do the same. Power is good but it just too loud when put it down.
he bridged the 2 pipes together in 2 spots. Making a H pipe. i'll get a photo and post it tomorrow
  • Like 2
Assuming you are starting with a red sport/400r with the factory akebono calipers, you will never need to upgrade the calipers/disc/pad size which is good news (mine really could do with a rebuild though, the auto braking seems to be hard on them). They are the same as the track spec 370z when people can't find a parts lookup.
Because I am/intend to tracking the car, I put race spec discs on it (DBA5000 series which are 2 piece) but for street use I would stick with factory until they need replacement, then put on slotted DBA4000 discs
Pads I can't help much, I went with winmax street/track pads but they are not what I would choose for street use; they have great bite and never faded on the track, but are dusty as hell
Fluid should be changed if you don't know when it was last done, I use Motul RBF600 and change it annually.
That setup is sure to be fine for any power level you throw at these for spirited street use. If you are doing full on racing of course sky is the limit depending on exact needs.
  • Like 1
Thanks mate , I'll let my exhaust guys know to see if that addresses the issue.
Thanks Duncan , they are the akebono calipers , for discs I might just look at getting the same size but possibly slotted units.
On 11/06/2025 at 3:01 PM, V35_Paul said:
2 spots that my exhaust guy joined the 2 pipes together
Made a big difference. I'm now able to live with it. I can make it louder if I want by removing the HKS caps.
Looks like a good fix , I might look into a HKS unit in the future but I had me exhaust guy look at it , apparently the resonators in the FUJITSUBO  - Cat Back were hollow (decorative resonators :)  , so he removed them and put in high flow resonators , that's made it little less aggressive sounding in low RPM's.
  • Like 1
Good evening SAU team , just a quick update on the 400r , just had the guys Lush Auto Spa (https://lushautospa.com.au/) do full paint correction and ceramic coating(Exterior and Interior) pictures look great , I'll be picking it up tomorrow.
Highly recommend Lush Auto Spa for anyone who wants their car to look its absolute best.
  • Like 3
  • 3 weeks later...
On 24/07/2025 at 7:22 PM, wizlb said:
I’m not sure what happened
I told them about sonic tunes free OTS tune and the next the I know .. I was booted..
To funny
That's strange , I'm still on there but not much gets posted on there .
  • Like 1
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
