So my question today for you guys is, and after looking everywhere I couldn't find anything. I'm really wanting to add a Chassis Mount Spoiler to my ER34 (GTT).
Does anyone know where I can get one, which is compatible with the skyline, and if it even is possible.
And if anyone has even done it. Thank you in advance.
https://www.sau.com.au/forums/topic/482240-r34-skyline-spoiler-questions/
1 hour ago, Roses Are Red said:
Just want to know if it's been done, If it's possible, and what it may look like.
How serious is the rest of your aero? is a normal body mounted wing not providing enough stability at high speeds at the track?
probably best to ask this in the Motorsport section
Why would it be legal?
Has it been crash tested?
Ever seen one ever on a production car?
Want to think as to how a chassis mounted wing somehow doesn't protrude
a) above the roofline
b) wider than the body lines
c) beyond the rear bumper
People who really require a chassis mount wing don't ask questions about buying one off a shelf. They would have made various other aero by themselves or a very expensive motorsport team.
It is very obvious that this one is intended to be bought for clout only.
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
