I'm looking for the PART NUMBER of the coolant drain plug that is located on the engine block next to the dump pipe and turbo. The car is a 98 R34 GTT with an RB25DET. The thread is a 14mm with a 1.25 head. Yes I've tried Repco, Supercheap, and Autobarn, none of them have the exact one. Any reply will be appreciated thanks :)
I picked one up from Nissan not long ago, part number was: 08931-3041A. You can double check on Nissan EPC data if there is any variation between our cars. Mine is a '99 ER34 GTT.
Edited by GoHashiriya
  • Like 1
  • 3 months later...
  • 3 years later...
It is the most woefully design part IMO. Tiny thin head that strips and rounds easily, with the plug semi-welded into the threads with light corrosion. Weld a big-ass nut onto the head, makes it soo much easier to remove. Will take a pic of what i'm talking about when the engine is out shortly.
  • Thanks 1
15 hours ago, GTSBoy said:
Never use thread tape on such things. Teflon thread compound, in a tube. Loctite, and all the usual other suspect brands have thread sealant.
Ah right, thanks. I thought because water is thin it might require some kind of sealant.
I'll put it in without anything.
Um, no. I said not to use thread tape.
You should have read the remainder as the instruction as to what you should use. My bad for not being clear enough.
  • Like 1
I just realised on coolant flush tutorials they don't mention anything about after putting on sealant how long to wait for it to cure. Say for example you are doing multiple flushes to clear out the system, so you need to keep removing the bolt and putting it back in but surely you aren't waiting 24 hours for it to cure other wise the job could take 7 days if you need 6-7 flushes.
In the case of repeated flushes, you wouldn't bother sealing it if it's going to be removed again shortly afterward. Any little leak is not going to be a problem. You just seal it up the last time.
I'd wait at least several hours, preferably a day, before loading any joint sealed with thread compound. It is an anaerobic sealant, meaning it should go off straight after being locked up between threads. But I find it is still wet long after use. Just give it some time to firm up before pressurising it.
  • Thanks 1
Ok, thanks!
Doing some research, these thread sealers (including loctite 592) take about 72 hours to cure.  Suprised it's that long.
38 minutes ago, Duncan said:
I've always just put that plug in dry (ie no sealant), it is a tapered thread so do it up "fairly" tight but not VFT and it should be fine
Yeah. I usually go by the torque specs. I forgot that Nissan recommends 1386b sealant on that thread, still can buy it on ebay actually.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
