I'm sure this has been covered somewhere but I can't find info.
What's the general consensus when it comes to checking bearings, can I simply re-tighten the nuts on the rods or do I need to throw em and start again. Are they a TTY bolt, it's on an RB30 if that's different to the other RBs.
https://www.sau.com.au/forums/topic/482795-re-using-rod-bolts/
On 9/5/2021 at 8:39 AM, killa-watt said:
So your saying once you undo em they are bin jobs
Yes, but not because they are TTY bolts (which they are not). It is because they are 30 years old, have done a million billion cycles and an engine builder is BUILDING an engine, usually with the intent to push it hard.
I agree to replacing original factory rod bolts but would happily re-use upgraded bolts next time.  Presumably you’re chasing more power than the original bolts were ever designed to handle plus the age factor so replace them now and they will be fine for the next build as well.
I'm in a similar situation. I've already assembled the bottom end of my 25Neo and next is installing the head. My engine shop said I'm good to reuse the factory rods and bolts (RB26 rods and matching bolts as it is a NEO bottom end, with forged pistons) for this power goal and application (street). I've also been told that there's not much point getting ARP rod bolts if I'm reusing stock rods.
This has reinspired the fear of god in me. GTSBoy would it be totally moronic to not pull it apart and bring the rods to a shop to get reworked for ARP bolts? I ask this suspecting you will say yes, but I still want to hear it 😁
Edited by CowsWithGuns
6 of one or a half dozen of the other. The expense is not huge and the effort is not huge, so you could say that it is silly to not take the opportunity. It's just sump off, rod caps and pistons off and then put it back together afterwards. It's just annoying given the effort that you've put in goes to waste.
On the other side of the coin - the stock rod bolts have been demonstrated to happily run at streetable ~300rwkW power levels without failing on many engines for many years. So as long as you don't plan to beat on the engine real hard, it will probably be fine.
At this point you choose your poison and you drink it.
Thanks. I've had some time to research and clarify my thoughts. 300+ rwkw is already incredible relative to what I had, so I'm going to put it together and and just stay modest with the power. If I really want to go beyond say 350 or get heinous redlines, I'll pull it out when the time comes and upgrade. This is only my first build too, I think I shouldn't overthink part selection lest I make some rookie mistake that causes failure anyway...
If my bolts eat shit, I'll be sure to report back to the community ;)
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
