On 07/10/2021 at 7:52 AM, NCred02 said:
This car has been a great project. There's always something to do
I wish the opposite for mine, for me it's been a bad project and there's always something that is broken LOL
I dream of a car that can be used, doesn't break with nothing to do!
  • Like 1
On 08/10/2021 at 6:11 PM, niZmO_Man said:
Off topic but my BMW has been flawless, 75,000 km. B48 is a good engine :D :D
This is the reality, everyone says they're unreliable but at the track it's always the Nissans being spannered on and the BMWs are just carving up laps.
To be fair mine is a FWD hatch that I share with my mum. I wouldn't track it haha. But the point is you get into a modern performance car and drive instead of fixing 30 years old stuff. Especially now that 90's JDM cars and parts have shot up dramatically.
  • Like 1
  • 1 month later...
