I'v got the autospeed boost controller with the supposed better regulator in my car at the moment and it doesn't hold boost well at all dropping about 2 psi after peaking at 14psi at 6k. It did this with the rb20 and now with the rb26.
Just wondering what boost controllers you guys use and how they make boost, drop off after peaking and spike if they do?
Any comments would be of assistance.
https://www.sau.com.au/forums/topic/48326-best-boost-controller-for-rb26/
I dont have a gt-r but i can offer comment on the HKS EVC5. I rate this controller highly, it does exaclty what it should do and has bugger all spike, even in different atmospheric conditions. It's steppor motor is 3 times the size of the apexi one, and the stepper, controler and the display unit each have a 64bit processor in them, pretty tech. stuff. The worst spike i ever had was 0.05bar, with the odd spike of 0.02bar (0.3psi) here and there, i've seen avcr's spike as much as 0.2bar, which is about the same as what you're unhappy about now.
EDIT: my evc5 also holds boost plus or minus 0.02bar.
-rb25
Hi Rowdy,
I use the HKS EVC4 in the GTR... after going throught the headache of picking the right unit, I spoke to Ben from RacePace & the Boys at ICE Performance, and they both said they haven't seen a boost controller on a GTR that works aswell as the HKS EVC units.
Go for an EVC 3 or EVC 4, they use the same stepping motors as the new fancy EVC's from HKS and there's a business seller in the for sale section that has one of each around $300-350.
I have the Apexi AVC-R. It's awesome.
Before I had it I just took out the boost solenoid and on a track day it must have spiked somewhere and I blew the pipe off the intercooler which ruined my track day.
Boost is super stable now, with no spiking on track or off the track.
  • 4 weeks later...
The avcr compared to the hks evc controller series is not so good on the grounds that the avcr has a single stepping motor to control boost and the hks evc's form I think the 3'rd model have a dual stepping motor which have a much better boost control.
Not true the HKS EVC has a single solenoid stepping motor.
I woudnt touch any of those 2 boost controllers. Both of them are outdone by the Greddy Profec B and Blitz SBC SPec R for ease of use and boost conotrol.
I wouldn't recommend the Profec B so highly, the Blitz DSBC yes.
Only 2 EBC I recommend is the Blitz DSBC or HKS EVC EZII. Even though the HKS has a single solenoid, what makes it control boost so well is the way the stepping motor works...like gates opening and closing.
I have the Blitz DSBC Spec R and am very happy with it... I am only running about 10.5 psi through the stock turbo tho... However I have heard great things about the HKS EVC and was going to get one but got a price I couldn't refuse on the Blitz one
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
