Hey all.
I searched the forum and found plenty of references to worn switches, but I'm not sure this is my issue because when I unplugged the connector from the brake pedal switch the lights remain on, the only way to get them to switch off was to remove the fuse.
Can someone tell me if the lights will come on/remain on if the brake light switch is disconnected, like as some sort of safety thing?
Otherwise, any ideas where to start looking for the problem?
Cheers,
Mike
https://www.sau.com.au/forums/topic/483336-r33-brake-lights-stuck-on/
The brake switch pushes on a little rubber piece on the pedal itself; if that brakes or falls out, the lights stay on. Have a look at the clutch pedal in comparison and you'll see where the switch pushes
Whilst true....
Opening the circuit should kill the lights.
This suggests a short. Which suggests that you should break out the multimeter and start fault finding.
I don't have a car handy to swing around under, but definitely if the stop is missing/damaged or the switch is mis adjusted, the brake lights stay on rather than off. I've had to replace the rubber piece in 2 cars now for this reason (our old navara worked the same way)
  • Like 2
Thanks GTSBoy and all. I figured that disconnecting the switch should kill the lights, but wanted to 100% sure before I start looking for obvious shorts. Trust this weird random crap to happen to me! At least I know what i'll be doing for some of the weekend. Think i'll start by pulling off the interior panels in the boot, looking for shorts and also removing the globes one at a time to see if its a dodgy globe. Probably then disconnect the boot lid stop light.
On 2/14/2022 at 11:49 AM, GTSBoy said:
Whilst true....
Managed to take a good look today, and found the remains of a 15mm round piece and a "mushroom" shaped piece of plastic. Really strange considering I had disconnected the plug from the switch and could see there was still one of these visible.
Turns out I should have looked harder. There are TWO switches, and the one I didn't see (its close to the steering wheel column) was missing that stopper. I haven't yet pulled that plug out, it's hard to get to, but i'd say thats the issue.
Why two switches though, redundancy? Some other function?
On 2/19/2022 at 2:44 PM, Millerman said:
Could be for Cruise control or gear shifter if auto
It is an auto, but no cruise control. Was looking at some pics of someone's blog on the topic, and noticed that the second switch isn't installed in his, and that's a manual. On his car they put the switch in the hole furthest away, man I wish that was the one that broke on mine, if you reckon that ones hard to get at, when its closest to the steering column its a nightmare. Anyway, ordered the part from JustJap for about 1/3 what Nissan quoted and it'll be here in a couple of days. So that's a few hours of next weekend accounted for!
  • Like 1
On 19/02/2022 at 7:46 PM, Duncan said:
In the meantime, if you need to drive, the wiring plug is probably identical (r32 clutch and brake switch are), so just move the wiring across to the working switch
Just be careful, its an auto you might not be able to release it from park if you swap the wiring
That small mushroom stopper is $10-$15 from Nissan now. I tried using a round top bolt and securing with a nut instead, it worked but made a metal clunking noise every time the pedal hit stopper, so I paid up.
Nissan Berwick quoted me about $30. JustJap have them for around $10ea
Ended up ordering from JustJap, price was decent at around $10ea and shipping was $25. Seeing as I was going to pay that much for the shipping, I figured I should get my moneys worth and bought the Nismo smoked side indicators lol
Anyway, glad I ordered two because the one that was left also disintegrated too 🤦‍♂️
I wasn't looking forward to replacing them because just to see what was going on I had to twist my body in a way no human being is meant to, and I knew it would be worse trying to get hands up there, and might also need a bracket to be removed from the steering wheel.
Pro Tip: Forget about removing brackets and having to shove hands up in to spaces they don't fit very well. Get a long flat blade screwdriver, like the longest one you find in sets (the ones that are so massive you always wonder WTF is that even used for) some blu-tac and a really decent bright light.
Start the engine, this will allow you to easily push the brake pedal down. Put a decent amount of blu-tac on the flat surface of your new rubber stopper and put that on the end of your flat blade screwdriver. Put the screwdriver and light in the footwell. If you are working on a concrete driveway, get one of those kneeling pads Bunnings sell in the gardening area, your knee's will thank you...
Open driver door as far as it'll go, kneel down, turn on your light and push the brake pedal down far enough to give enough clearance between the tab that holds the stopper and the brake switch(es).
Carefully pick up the screw driver (so the rubber stopper doesn't fall off) and, using the kind of hand eye coordination you normally reserve for a game of championship darts at the pub, push the screwdriver with the stopper on the end up inside the dash and past the inconveniently placed steering column bracket, aiming the mushroom shaped end for the hole in the brake pedal tab.
Once you think you've got it there, push the screwdriver hard so that mushroom shaped end is completely through that hole.
Remove the screwdriver and if the stopper isn't on the end, or sitting back on the floor of the footwell, slowly let the brake pedal return to its normal position (I pulled it forwarded a little and held it for 10 sec).
Push the pedal back down and slide a finger to where the switches are and pull away the blu-tac and if you can, give each stopper a reassuring push.
And you're done. Grab a <insert drink of your choice>, make your mate press the brake pedal while you marvel at the awesomeness of your work at the rear of the car.
Oh, and if you're wondering, the side indicators are removed by sliding it towards the front of the car and when its moved as far forward as it will go, slip a fingernail under the edge that's closest to the door and pull it out towards you. No tool needed. Twist the globe holder to remove from the old indicator body. Replace the clear bulb with the orange bulb in the Nismo package, put bulb holder in new clear indicator and twist to lock in and push the indicator gently back in to the panel. Easy.
  • Like 1
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
