Hi Guys....Question from a "Pommie".(England).
On 2/26/2022 at 10:53 AM, GTSBoy said:
It's worse than that. I've been stuck in Bunbury for the last 8 months anyway.
As to the hubcaps - I'm wasn't sufficiently familiar with the movie to know what cars are in it. Apart from the car chase, the rest of the movie is shit. I'm not about to do any research to look for a car in it that doesn't even have those hubcaps on!! I've got infinite hours of youtube videos to watch first. But.....are you sure that they are Charger hubcaps? The do not look anything like Chrysler/Dodge hubcaps of the late 60s (which were universally pretty f**ken ugly!). They do look a lot more like GM product of the late 60s.
Hey there is nothing wrong with Bunghole. Sure it’s no Birmingham, but we go alright.😃
Man even I had to google Bunbury, my knowledge ends at Mandurah
Anyway, pistons/rings, rods, bearings + gasket kits, timing belts etc are all readily available in a range of prices. I use Justjap.com but there are many other choices too. I'm sure others here can recommend.  Machining can be done at any competent engine shop and there are no real tricks required inside a non-turbo, standard motor (noting you could take the opportunity to turbo it because Stageas can really do with a bit more oomph, but it will triple your cost by the time you add computer, injectors, exhaust manifold etc). If you do a rebuild, make sure you at least inspect and possibly replace the oil pump, and replace the water pump, timing belt and timing belt idler and tensions bearings and the bolt and stud that hold those on.
But the reason I asked is that the failure you described is very unusual, particularly in what I am guessing is a non-turbo, unmodified engine. Assuming it is internal it will be interesting to learn what failed.
Hi Duncan.......I think I may have caused the problem !!!!   I have always put Shell Hi-Octane fuel in EXCEPT when I was a long way from home & half filled the tank from TESCO with H10 fuel 😒
Am I right in thinking that the Turbo version of a RB25 runs with LOWER compression pistons compares to the NORMALLY asperated engine ?
My Stagea APPEARS to be a RB25DE NEO 25RS (Series 2)....Is there an easy way to confirm it IS a 25RS model ? A badge on the tailgate says it is !.......Is a level of engine tune OR body/interior trim ?     Can't find anything printed (so far) to help me.
Bet you can't believe how LITTLE I know about my car....Other than I LOVED my R33 GTS, regretted selling it, saw there was an ESTATE version....AND WANTED ONE !!!!!!!
OK....It don't go into "Time Warp" like my R33 did......(but I've got grey hair now) my reflex reactions only work up to 132mph (officer) 😆
Good Night (1:56 AM)........................Mal T
On the firewall there will be a japanese build plate with a number something like WGNC34-xxxxxx. You can put that into a VIN search like here and find the factory spec of the car - https://www.amayama.com/en/catalogs/nissan?_s=h
And I understand about Stageas....I bought an auto, turbo one about 15 years ago. It is now manual, has mostly GTR running gear under it and makes about 400awkw from a 3l engine and largish turbo. Still pretty low key car externally though.
I've been here so long that I now have to choose between a facial piercing or a neck tat if I want to keep getting let into the Rose Hotel.
Wait, what? There are standards for getting into a pub in Bunno? Gentrification must be happening. Flanno and a mullet should get you anywhere.
  • Like 1
Hi Duncan.....That Amayama is a BIG help to me.......THANKS !
I've got my "Aussie" bearings now !......Bunbury is South of Perth on the West Coast ....So I've put Hong Kong as the 8 hours ahead of GB time so I don't message you in the middle of the night....So you must be getting up for work !
GTSBoy...............It's VERY unfair nickname to refer to your city Bunbury as "bunghole"....that's a Bevis & Butthead expression....'cos your city lies on 3 rivers with GREAT water sport facilities....It is a common human failing to get complacent with our "every day" surroundings & "take them for granted" !.....You are lucky "bungholers" 😂😂
There is an inversion of the seasons between us....May to September is SPRING & SUMMER to us but AUTUMN & WINTER to you guys !!
Having priced out some basic "engine internals"......Have started saving some of my £171 per week for a head gasket 🤣🤣
Time to hit the sack...........Mal T
I didn't call it bunghole. That was djr81, who actually lives here. I'm just stuck here by a combination of a shitty project and the border being slammed shut for the majority of the last 6 months.
I call the place Bunnabama. Also sometimes Buntuckey.
You're right about the water sports. I entered my first ever long distance open water swimming race on the weekend. I've never been so fit as I have this summer.
GTSBoy......Judging by the time you must be "having a few tinnies" by the water.........It looks from google earth an idealic place AND you can scare the "natives" with your "rapid metal" (sorry officer....didn't mean to wake you ! 😂).
Just sorted in the achives ......thought you might like to see how all MY "locals" ever saw my car 🙂
  • Like 1
Good Mornin' Duncan............Thanks again for the info about Amayama site VERY useful....for parts & prices !
One problem i have ....Can't read the "Size Chart" for the Bearing Crankshaft ...Because they are in japanese....I set the language to "English" in the "header" at the top of the site....but please see attached document to see problem !!....How do you guys get round that !!
Best Thingies......Mal T
Amayama Doc 01.pdf
Mornin Duncan.......Thanks again for the Amayama site VERY helpful sorting out bits !!
How on earth do you manage to read the "sizing chart" for the Bearing Crankshaft from the chart ??.....I have selected "English" in the "header" but this bit is in japanese (see enclosed document)
Amayama Doc 01.pdf
You stuck at Albemarle?
Sorry it is a cultural thing. The only way to show any respect for anything is to relentlessly take the p!ss out of it. On that basis: Mal, your boat appears to be missing a bunghole.
A random photo of Bunghole Skyline for those playing at home. As distinct from a Bunghole Skyline of which there appears to be fewer and fewer, sadly.
Edited by djr81
  • Like 1
It's OK, you don't. You buy a set of ACL aftermarket oversize bearings and machine the crank to suit if you can't just use standard size bearings. The Nissan 1/2/3 grading was for very small variations on a new crank, it is not worth worrying about these days for an un-machined, second hand crank with a few klm on it.
Sadly, there's more than one misapprehension regarding my circumstances in your post. First up, I don't drink, so there's nothing to take the edge off. Second, my car is 2600km away, at home. If it wasn't for the Ctek charger the battery would be f**ked because I haven't driven it since early August.
Bunno is pretty, in the summer time. Which, sadly, is coming to a rapid end. It's hot today, but the mornings are getting darker and colder and ti won't be long before it is raining every day again.
Yes. Between the shitful nature of the place and the border closure, I have been receiving it dry and without protection for many months now.
Yeah, I only see that ratty black R33 regularly, and one or two others from time to time around here. At least there is plenty of old chrome bumper stuff paid for by exorbitant tradie/FIFO earnings dribbling around on the weekends.
Yeah the Skylines went and then it was all LS valvetrain upgrades and ECU flashes. Now it is all lift kits and DPF deletes. When I occasionally drive my old 32 I see people losing their sh!t at the sight of it.  Cant quite reconcile it still.
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
