Need a hand. I was about to start redoing my stock wiring harness for my elite 2500/P&P adaptor and can't seem to find a wiring diagram that shows what pin on the elite is connected to what pin on the stock ecu harness with the adaptor.
The Haltech adaptor wiring diagram only shows from the elite connector to connector going into ecu adaptor and not on stock ecu connector which in my opinion is useless. I know I can just presume what pin it is on based on the descriptions or test them one by one but this wiring diagram must surely already exist?
Thanks
https://www.haltech.com/product/ht-151357-elite-2500-nissan-skyline-r32-33-r34-gt-r/# and download the quickstart
then use this to work out what you need, nicely colour coded too:
Nissan_R32_R33_R34_GTR_RB26DETT_Pinout_R
  • Like 1
Thanks a lot! That's a lot more complete then what I found. Cheers.
On 4/10/2022 at 6:56 PM, GTSBoy said:
I struggle to see your problem. The stock ECU pinout diagram exists. Simply hold it up next to the Haltech one and ... presto?
Nissan R32-R34 ecu pinout's don't show all pin connections with the elite 2500. One example of this is Pin 113 which is usually a "N/C" but is connected to Pin B17 on Elite 2500. Pin B17 is surprisingly not even mentioned in the Haltech adaptor manual.
That makes for a spare DPO or ignition driver that I can use pinning directly into the stock ecu connector. It also doesn't show which grounds are jumped within the adaptor, etc.
Cheers.
Edited by TurboTapin
That's correct, there are a few pins that are not used from the Haltech that are randomly pinned into the plug/play adaptor and there are some pins that supposedly should be in series from one plug to other is actually non existent lol..
I just depinned them and connected it straight onto my own harness (Haltech -> own harness) - less mucking about.
I just wrapped up buzzing each pin and wow I see what you mean. I was rather surprised by a few oddities found. I'll toss it all into an excel and post it here at some point this week.
  • Like 1
I suppose the two best options are (in cost order):
  1. Pin the Haltech Elite direct to your OEM harness, i.e. delete the plug & play adaptor & OEM connector
  2. New harness, mil-spec dis dat, IG fame.
I'm sticking with the P&P harness but I agree with option #1. I have a feeling most unconnected wires can be solved with an undocumented jumper setup within the adaptor. I'll report back once confirmed.
  • Like 1
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
