Hi all, I've just bought a set of V35 OEM 18x8" wheels for my car (same as in the pic). A bit of a curious question for some but what is the loading rating of each wheel (and not tyre)?
Each wheel has lots of numbers and references cast into it including "front" and "back" for fitment but nothing I can identify as a wheel loading.  The only other thing is that the front wheels have AL400 and the rears AL410.
These aren't for a Skyline but as it turns out Skylines have the same wheel specs as several other cars (including mine) with the bonus of being lighter. I just need to get a centre bore adaptor. So the final check I need to do is for the loading rating.
Cheers
If this is to advise an engineer of the load rating of the wheel so he can sign off on it for some bullshit technical regulation, then tell him to pull his head in. As Duncan ^ says, this is not a number that you will find available for almost any wheel. Therefore it is almost impossible to satisfy any requirement to provide that number.
A pragmatic approach might be to say that they came off a V35, and so their load rating is going to be more than sufficient for the heaviest variant of that model that rolled on that wheel.
  • Like 1
Thanks mate. They're for an early Toyota Kluger...yeah I know but don't laugh there's a point to all this.
All wheels have a minimum load capacities. They're usually (but not always) stamped on the wheel or otherwise available from the manufacturer. There's also a basic calculation on the minimum for each car. Roughly the maximum of all weights (car, fuel, number of passengers, boot capacity, roof rack capacity, as well as max tow ball weight) divided by 4. Another calculation is 50% of the maximum rated axle load more useful for cars or utes carrying heavy loads.
For the V35 is about 450kg per wheel. For my Kluger it's 565kg. These are the minimum and load capacities are always much higher to take into account bad roads, potholes, kerbs, etc. The wheels I have at the moment are rated to 1200kg and weigh 15kg which is why I want lighter ones. I have a set of Lenso's off a Skyline rated at 690kg and weighing about 9.5kg but prefer the V35 wheels.
I expect the OEM 18" V35 wheel loading is between 750kg and 950kg but want to be sure.
Edited by Stratus
Like I said, I've not seen published max wheel loads, and most V35 information is out of Japan so Japanese only. Perhaps a path is to look into any Infiniti G35 information from the US.
+thats a little weird. The same size & width, but different identifiers. Are they different offsets between front and rear?
From what I understand the rear tyres are wider (but the rims aren't staggered and offsets the same) and to prevent the rears being put on the front by an absent minded tyre driver the rear rims had a small stud. The stud would stop the wheel being properly mated to the front hubs. My wheels don't have the stud but they were on a Ford before and apparently easy to remove.
I'm not familiar with the V35s and could be quite wrong about the wheel differences. It's what I found searching online. Pretty much a wild guess but I was thinking AL400 and AL410 could be a clue with AL being aluminium (from the periodic table) and 400 and 410 a "gauge" of aluminium...
Edited by Stratus
I've never heard of wheel loading to be part of engineering cert. Can you provide any links? I'd like to read on the regs. Just curious.
There are so many dodgy wheel companies, that any government body that enforces wheel loading will put half of instagram wheel advertisers out of business.
The requirement is set by the Tyre and Rim Association of Australia and is located at the Australian Standards 1638 Motor Vehicle - Light alloy Road Wheels section of their standards manual (see in blue). But there's a catch which I'll go into further below and is why it be understood this post may be incorrect.
Clause 8 MARKINGS; requires that Light alloy road wheels shall be legibly and durably marked as follows
(a) In a position which is readily visible when the wheel is correctly installed on the vehicle and without removing the tyre. The marking shall include the following details:
(i) The manufacturer’s name or trademark identification.
(ii) The wheel size.
(iii) The offset value.
(iv)
The maximum wheel loading for which the wheel is designed.
(b) Anywhere on the wheel. The production period identification, in sufficient detail shall be marked anywhere on the wheel at a convenient position, to enable the tracing of the wheel to alloy melt analysis and heat treatment records, i.e. batch/year.
The marking shall be cast into the wheel, or made by any other permanent method.
The catch is that the Standards Manual must be purchased despite being referenced by state and federal legislation or rules and authorities. Quote from the association's website: "Annually the Tyre and Rim Association of Australia publishes a comprehensive Standards Manual that is available for sale."
The requirements are referenced or mentioned on some wheel dealer websites and some forums but these aren't the primary source.
From the Vehicle Standard (Australian Design Rule 42/05 – General Safety Requirements) 2018
From Vicroads (I couldn't locate something specific for NSW and didn't look for other states)
From the Victorian Automotive Chamber of Commerce (VACC)
Lastly this comes from a wheel manufacturers website (Ozracing). This may only be valid for aftermarket wheel manufacturers...
This bit comes from the first part of the Australian Standards 1638 but the rest needs to be purchased...
Edited by Stratus
  • Like 3
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
