I let my Subaru impreza 2.0 ltr automatic 2001 sedan get to operating temperature (or I shouldn't be using this as a measure for the tranny?) and it was idling and was showing transmission fluid is low (apparently wasn't running for long enough), there are no leaks and when I drove it to the shop which took about 10 minutes or less, I checked a few times and the level seemed fine, but when I got home it was low. Seems like the reading is constantly different, I checked on another car I have at home and similar story.
I also put the car in neutral and hand break up.
Any ideas?
https://www.sau.com.au/forums/topic/484058-atf-level-always-different/
2 hours ago, GTSBoy said:
Always do it on a level surface. The same level surface. The place where it was parked at the shops only has to be 1° sloping left, and the place at home 1° sloping right, to have a noticeable effect. Any more angle than that just compounds the deviation.
I did on my driveway should be straight. I got some photos here: With picture 3, I might have held it upside down so keep that in mind but generally it's showing as image 1-2, and you can see some red fluid towards the full line.
I've got a 2013 Impreza so not 100% sure if this will help you out. I've attached the workshop manual for my Impreza here.
I used a cheapy OBD2 bluetooth scanner and a phone app to check the gearbox oil temp the last time I changed the oil.
Cheers.
I just re-read what you wrote and see what you mean, because at the shop there probably was a slight tilt.
Operating temp for trans fluid is about 80-90° C I believe, this is the temp for hot check
I always take my slushbox for a at least a 15 minute drive to do the hot check
You typically can see the change in oil height on the dipstick between "cold", "running but not at operating temp", and "operating temp (hot)"
Actually reading the dipstick correctly can sometimes be an issue due to splash
http://www.agcoauto.com/content/news/p2_articleid/89
Disclaimer: I may be talking apples and oranges, my slushbox is a 4l60e in a commodore, but I assume they would be similar
  • Like 1
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
