As I went to paint my engine bay I had to remove the entire subframe and after looking at it for a little bit I then started to compare with pictures from others and their R33s, and mine looks different to theirs! What I mean is, the two faces where the engine mounts bolt up are completely in-line with the entire frame, whereas all other R33 GTST pics I've seen have the locations sticking further outward (towards the front) and are in-line with the forward-most bolt. I am attaching a picture of my subframe (LEFT) and a random R33 GTST subframe (RIGHT). My chassis is an ECR33 factory spec 2 GTS-T RWD. Is this some sort of oddball that left the factory or has the previous owner done a subframe swap? If so, I cannot imagine how an RB20/25 would fit inside the bay with the mounts situated close to 10 centimeters back towards the bulkhead.
Interestingly there is not a single thread or video talking about such differences so I am coming here for your advice.
https://www.sau.com.au/forums/topic/484135-r33-gtst-front-subframe-differences/
Gosh darn it, it's already been hell finding the missing parts for this car, now a subframe?! Will have to modify the mounts or the subframe then but I've got no idea how I would get the motor to sit like OEM. What a mess. 😢
So just a little update for anyone wondering, this has been 100% confirmed S15 SR20 front subframe. The entire rest ofthe front suspension is bolt on, control arms, R33 steering rack, hubs.
While I'm still looking for a GTST subframe I decided to make my own adapter brackets for the engine mounts, similar to the kit ISR sells but just the two mounts. I got the angles and distances right (the bolt hole centers on the adapter brackets need to sit 125mm FORWARD of the S15 mounting holes!) and the driver side bracket needs to be angled slightly more than the other.
However even with these, I cannot mount the custom turbo oil return line I have made for the HX35. The tube bends too far out and clashes with the S15 stock mount point. For this to work, a significant portion of that point will need to be cut out just so the pipe can go through it. Definitely not something I want to do.
Thanks for the offer, but I have already found a 25det r33 front subframe from the UK and it's already on its way to me. Even still, I am slightly worried the engine mount and bracket combination might be wrong. Why did Nissan make so many different  variations of parts on these damn cars?!
They didn't, really.
There's cars based on the R chassis (ie, Skylines Stags) and there's cars based on the S chassis (Silvias and Ceffies). And there's 4 cylinder engines that were mostly in the S chassis cars but sometimes turned up in the nasty budget versions of the R chassis based cars. And there's the RB engines that were pretty much exclusively in the R chassis cars.
There are engine mounts for each type of 4 cylinder engine in the S chassis cars (CAs and SRs). There are engine mounts for the 4cly engines in the R chassis based cars (probably the same as for the S cars). And the RB engines have a couple of different types of mounts - essentially the RB26 and all the others. You can pull an RB25 out of an R34 and drop it and its mounts into an R32.
This just keeps getting worse and worse. I'm at my wits end with this shitbox already regretting getting a Skyline. So I finally got the R33 25det subframe shipped to me from the UK and when I test fitted it what do you know IT ALSO DOESN'T FIT!!!
I'm throwing a tantrum here but rightfully so. Can someone tell me what in the world is the problem? Is the problem the fact that its a 20 block? I assumed their mounting locations and bolt holes are identical across 20/25/26? The rubber mounts themselves are not the issue as these are  BMW mounts 100% identical to the Nissan square ones that came (they were torn and unusable). Regardless, the problem is the surfaces are not remotely parallel to each other so it's not the rubbers.
I'm suspecting it's the metal brackets. The person I got them from said they were from an RB20DET and he assured me they would fit a 25 block also, which in turn would logically mean they would fit an R33 chassis?
Unfortunately I am out of funds for this kind of crap so tomorrow I will be trying to cut these where I have marked with yellow lines and welding a new gusset. My understanding is that the oil pan's bottom naturally is parallel to the ground and to the subframe so I'm using that as a guide. I don't know how wide the gap needs to be between the oil pan and the subframe either. What a headache 😖
OK, so firstly, RBs do not sit parallel to the ground in their engine bay. I don't have an rb25 in an r33 handy to check what angle that combo sits at. A possibility is that you have the brackets on the wrong side?
Secondly, I'm not sure it matters but the the mount brackets look like rb20 not rb25. rb25 look like https://www.jdmgarage.com.au/shop/engine/engine-accessories/engine-crossmembers-and-mounts/rb25-engine-brackets-pair/. Also note the mounts you are using don't have 2 studs at the subframe end but I guess that is your choice
I know the engine sits tilted towards the passenger side but the oil sump itself is tilted also and it looks to be parallel to the subframe and ground.  I also thought I had the brackets wrong way round so I switched them and the bolt holes did not line up at all, so that wasn't it.
After further research it appears I do in fact have RB20 mounts which are paired with the rectangular Nismo rubbers (40mm high), and the RB25 mounts come in two kinds, cast aluminium or stamped steel that are paired with the big circular rubbers like in your link.
None of this was really documented anywhere so hopefully this thread will shed some light for people in the future.
  • Like 1
Need to use the matching bracket to subframe.
r32 cross member to rb20 brackets
r33 cross member to rb25 brackets
r33/rb25 from memory have 2 types of bracket a steel and cast aluminium.
Project cars are fun aren't they.........
  • Confused 1
Last update to this, I'm probably the only person who's ever going to be in this pickle since I know you guys in NZ/Aus have an abundance of the right parts, but still I had to improvise because shit is just too hard to get and overpriced. Ended up modifying the RB20 brackets and they ended up really nice, close to OEM and the motor sits good in the engine bay. It may look cocked to one side but that's because I was supporting it with my jack at the rear of the sump. I am confident once I get the transmission on and its bracket, it will line up true. I even slapped the head on it and tested my rear head breather, it has plenty of clearance from the heater hoses and bulkhead!
312709579_3015904008555769_8129993717735555993_n.thumb.jpg.7ca19095ee21d8de3c5f38d45fc35c54.jpg
310980571_651384669725199_423654037759109634_n.thumb.jpg.ab9bc505467e56ad9053ce3237a86b85.jpg312705278_650613976709740_1390925090055558928_n.thumb.jpg.0040f57e61830c5a880e9d8a92ff403d.jpg
Edited by Neostead2000
  • Like 1
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
