Hi there , I'm new to forum and new R33 owner , based in NZ .
I have noticed this component under the center console , it has the red line through it . What does this component do , indicates what ??
Appreciate your collective help .
https://www.sau.com.au/forums/topic/484136-g-sensor-r33-series-2/
The AWD or A-LSD system uses it to determine lateral g of the car and adjust the transfer case lockup or A-LSD lock pressure accordingly.
If that is your G sensor in the pic, it does not have the high impact red line showing.
If yours has a more obvious red section in the centre glass, it has had a high G impact. However, the shock indicator is physically separate to the actual g sensor electronics and is only an indication that the G sensor might be faulty. If your ATTESSA is working OK I would not worry any further
Thanks ,  I have A - LSD , and the sensor has the redline showing so will that mean that the A LSD wont be working ??
No. Not necessarily. Duncan told you that already....
My underline and bold emphases. Just substitute ATTESSA for A-LSD in your case.
But, if perchance your A-LSD was not functioning properly because of this failed sensor, then it is a prime opportunity to fling the smelly piece of crap in the bin (the whole A-LSD system) and replace with a diff that actually works properly.
thanks for that reply , what would be the test to understand if LSD was working / not working / functioning properly ??
haha yes, count the liquorice strips left afterwards. 2 strips good, 1 strip bad.
Sorry, I see your profile says r33 gtst, I had assumed gtr, didn't realise gtst with alsd had an attessa sensor too
The A-LSD controller modifies the slope of the LSD lock pressure vs TPS curve depending on how much lateral g you pull. The more lateral g you pull the harder it locks up: https://sci-hub.se/10.1016/0389-4304(94)90219-4
Seems kind of suboptimal to have an open diff any time you let off the throttle but someone at Nissan thought that was a good idea.
Reduces understeer. Remember, these are the same guys who came up with HICAS. It wasn't about making the best driver's car. It was about making something that sounded sporty and worked with very sub-optimal drivers.
  • Like 1
Not really fair, this was all mind blowing stuff back in 1987 or whenever the program started, and it was ahead of any other car of the day in multiple dimensions.
For sure, doesn't look great in 2022 though
HICAS didn't look great by the time the cars were only 10 years old. It was already the butt of jokes about cars trying to kill people. I had to "fix" my HICAS upon commencement of ownership in 1999. That's only 10 years from first R32 release, 6 years from manufacture of my car. Bastard thing was dangerous. Wasn't worn out, just had a (deranged) mind of its own at anything above 7/10ths. And that's ignoring the occasional outright panic mode where it liked to crank the rear wheels to full lock at 80km/h.
Just not enough processing power, algorithmic development and designed experience (in terms of what actions are actually required, and what actions are definitely not required) at that point in time to create a system that was actually going to do what was on the wish list.
Did you use the bar lock out method?? . I got a bar that wasn't installed when I bought the car . i don't think the HICAS is working as fluids are all gone .
Not initially, and also not ultimately. If the HICAS tie rod ends are in good condition, then the HICAS rack itself can serve exactly the same function as a lock bar. All that is required on an R32 to kill HICAS is to pull the smaller of the two loom plugs out the back of the HICAS CU. Stops working, no dash light (probably because the dash light wire is on that connector!!). The HICAS CU will lock the rack under a fault condition, meaning that it is "fail safe".....for a given definition of failsafe. I just happened to find a loophole (the small loom plug) that allowed me to exploit the design.
Later, I swapped the original HICAS rear subframe out for an A31 subframe with no HICAS. This is basically equivalent to fitting a complete HICAS eliminator kit (as opposed to just a lock bar). Lock bars keep the HICAS tie rods and they must be in good condition (ie the rod ends not worn). Eliminators can and should replace the original tie rods and the rod ends, replacing them with the sort of bushing that is used on the non-HICAS cars anyway. I just skipped all that aftermarket crap and went to an OEM Nissan solution to the same effect, that also happens to look completely factory, so that there are no obvious "steering system modifications", which would trigger raised eyebrows on a roadworthiness check. My car was going to have to go over the pits at Regency as part of the engine transplant that was happenign at the same time, and it sailed over without a word said. A lockbar or eliminator kit would possibly have got me in trouble.
There is no "fluid" iin R33 HICAS. This was the next generation of HICAS where the rack was electrically actuated.
As part of exploring G sensor and  A LSD i have found the leak in the the LSD pneumatic unit .
Seem like a repair has been tried before , un successfully !! Looks like a Pressure sensor of some kind .
Aside from binning the diff does anyone know what this part might be , as in genuine number and /or a non stock replacement part . thanks in advance .
PNazOiBVhccrlrZCsNiWG6W5Qn-1tTnpt1AHpH1e7j-RXxAjoo6zVjH4iqivUIl9kIEGODJiPTZl7ptUqzbZNL8oMa0djJWsUdmJE1FAdrGwv2shSVEeE_UsgWZFWLkN3zV3rSoMn19VTG8E_AuSYAgCPr5HXHjOAND2wiRwtXlPLZVndkcnQwcJB1JM_kkgV7vRZ3_6s_caYJMrLsAONiq7yU58lXKMa4b-mNHrYEtTBbH2v_ZKp29LEyRcPkSkpX9tlWrygqK_X88MRzKfAlUfOLmw0JcLA4rFQymVe2Lrqp3iCkrhrbBzWpQzsuZZnAN04TJWnkJ58XsTpqEIdfsWEC26DwtbzpAEwiG7bq_wovuT9UoEVQ07ps7EKVehRzlCqKlXiaqhr6IoerGMx-J4GqztSyc2HSNXJJFJGPzb5A2DjdrQ-IgDL04OkMUZ6EtmX7PUl2yd-mbP0KyniIYJEoDod3JyqM2s4tHKVviCmyq2IbH7v9W0kg6Gk4LY9FeVexvTjNngDqMINSuv_52iU18TQYPUNTHPRh9ZNpbob0O5ZGmiEyzGtifrDZgopj9x0F80C-YoGhVnioYRNFoW7JOJV1_9Atge85JeS-TemBZFPWJ-hPCulWfdwcQUGPgQYfBCJ0k8PNS6ItT7QFvrICfp2dHYznmxrSjWVwgoDRVU9vyOgHmZx1mLXtlBdYiXoGu4VFYiV3-W9-Tr6CS4mCFkNGDozJbeIerVgztJVSxsOzhHMWZpynFNgFuTksHk2EwS2-fZFNhWfq9IzvymweJCF2wpaFhpPmuf66TMvFeb5RM8KIoM6FilPwMoh8AHqlIYQMZhcxoxoQvC9DuoEa0c_MV8h3WmSCl4-z5rwre2VEQmBeNtO3aBK5lmj1tDoGfX3x6lAHG04iA67MUlzgRCyIHbIE3P50s5QNRJiDXMkg=w703-h937-no?authuser=0q4YJyw68VXn7wdqD8v77FZOuabW3gUPfWMFUJze2rGINb-24ty5K-PBHVlTTvj-UD0D6wuTKL8Zeh4pK7IpRJzUji9uWFjIZRTTpuzWdOaz97deUUzL3foSHVPsWkQXVQ5Rlmkxfjt2oBR0TS2yj9HPHupuJfAvhcIb2T8KNgdGpfn_jC0vRTEK9r6Qo6B6gMER9gU4Wgjbl9mQq_T2JG_pApfMTd9Rx-5CSYGqp1l_h96kK3NfooTjIwM9STQpTJq44ApEVCNaj4zFy8BTs3LYrAhd_7_oZdDEJ0eNqQTY1VSK1A_0bGpPq3wIgrGB2ZJNlgAAwCqHR29JnZVmLTWv-hahNMzK_w9IRTtdGii8qGlyrhkf7GZDUCf48zgLATBX5MigkNdyHuU_jsoAlYly3uIJn_vRuGBODoIhgW5iZ_Ut8CSYFQ9apBNlk7uMUn6rxGGs_5sgL87qRL-nWAFYflAlMrM9svTJPLuPfLUdWgfH4UZFTZluLcpbZlh49yoXRrqvGnswmVOJpmvPiLgcHoimw9QQUjTKGq9IUtZdQZYcbFB_iF7QvzcWAi2qcLUfMFdS_ZJtHVzPuswaalcod2buuILriMXxgqmno_hZbV2qmCXh_2UvN1OBCx2T99tFuRNHIp1W-tipNvO0ZSMJhWoOTgA8HaVzNYgL3_E-XF6x_dMjx5Hz_v5xTp_mn9OqkvJHgoyVyXWnzLjkpWnkWz_mz_K3GhgmQ-UcGy3KOBoo4aMHgSdIdAyzsfXRVNeeqeQehK-66kYL0W0XqiqQc5ER0OR163lsntjCaBQQ0FLpE6QaF9bQbUqs4R1vTekY10bW9hNUKxnTkIEzdg398YyV68Ghex5gy18-C0ygl8-DRBmhEAxYU3yDxroWg26973XY3yOg9eSfcBjBFsqgk59E9ar-lOCdDsZcbOQMMCVmdFw=w703-h937-no?authuser=0
I don't think you can actually buy one separately as OEM. In theory you could get the whole unit sent off to Nismo for rebuild but the cost is hilarious: https://www.nismo.co.jp/heritage_parts/repair.html
If you are confident it's just the pressure switch and not anything else FPG sells the pressure switch by itself, not a direct fit but close enough: https://frenchysperformancegarage.com/products/fpg-nissan-gt-r-attessa-pressure-switch-replacement
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
