35 minutes ago, damnonrs said:
i will hard wire it for now until my problems are resolved and get it dyno tuned again. i'm just worried about fuel temperature running the pump at 100%, is that a problem or its ok to just have it on full blast at all times
It's fine, main concern with a big pump is you overwhelm the pressure regulator but if you fit an aftermarket high flow one it shouldn't be a problem until you're really flowing a ton of fuel.
An 044 or 340 is generally not big enough to stuff around with a properly working stock fuel regulator, but his reg looks pretty suspect and need of replacement anyway.
so i spoke to my tuner, and he said he just changed the wiring that goes from the battery to the pump, the line in the fuel tank and the wiring in the fuel tank is still OEM at like 22 gauge or whatever it is. is that essential to upgrade or would that restrict the voltage?
The shorter the wiring run the less resistance there is but you'd have to actually measure the voltage drop to be sure. If you've confirmed that the fuel pump is running at 100% flow all the time then your problem is almost certainly related to the regulator then. Every other part of the system is running like it would be at full throttle.
  • 10 months later...
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
