6 hours ago, funkymonkey said:
So introduce Toyota Kanban system for lean manufacturing to a lean manufacturing business?
Getting a business to pay for that setup, coaching and training would be a mission.
I doubt small businesses will see the value or even pay for it.
On 11/12/2023 at 10:16 AM, Komdotkom said:
I tried to fit mine today, manifold drilling was miles out and will not fit. Woeful alignment, who knows what the ports will be like...
Waiting to hear from Artec next week.
Interesting 🤨
I bought mine this time last year during the Black Friday sales so would consider myself in the 'early' buyers and mine had none of the above issues u mentioned..
The biggest gripe I had though is i bought new studs and nuts (tiutanium) at the same time and without heavily modding an old 12mm ring spanner I never would have been able to tighten two of the nuts..
I had no issues controlling boost (running a 45mm TurboSmart gate), I'm not making huge power / running huge boost though so probably not the best example...
Edited by mr_rbman
  • Like 1
On 14/11/2023 at 4:26 PM, Dose Pipe Sutututu said:
If you look at 6 Boobs, their single gate "twin scroll" manifold, where the start of the bend for the wastegate mount,the division stops, thus you're not maximising the scavenging effects.
My 6 boost is divided right through
  • Like 1
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
