So yesterday, giving the car an once over before tomorrow night's event I noticed something rather alarming.
The Ross PS idler actually fouls the AC compressor belt.
You can see the scoring on the lower belt. I tried using the RB26 spacer included in the kit but it ends up only supporting 2/3s of the belt and the other 1/3 overhangs. Either approach is going to be good for tomorrow night so I ended up using a 4mm or so washer and packing out the bracket to move the idler forward. Seems clear everything now, however the idler bracket bolts are now really close to the PS belt itself. (Didn't take photos of this, finished up late night and just wanted to go to sleep).
I've contacted Ross Performance and hoping they are able to machine down the RB26 spacer, here's hoping they reply at all lol...
I'll take a photo of what I've done tonight when I'm back home.
It seems they didn't design this for RB25 motors with AC, or thoroughly test fitment on all combinations and permutations.
Then again their target market are heavies.
Added spacers to clear the AC belt and had do remove the spring washers on the bolt side to allow it to clear the PS belt.
Fun times, not. Piece of shit car, always spannering the lump of shit before events.
There's about 8mm of clearance to the fan blade, camera angle makes it look much closer.
Will trade for a F80 LCI M3 if anyone is keen?
  • 5 months later...
So update, Ross said they would review it and they never got back to me.
After a couple of follow ups, nothing. Even tried messaging them on IG and nothing. Guess I'm not a big player (spend heaps) or have any social presence.
They're happy selling products that semi work (works great if you don't have A/C) and when you try to provide constructive feedback you're met with radio silence.
Guess it will just have to live with the spaced out bracket using washers - better than nothing, just annoyed I bought something that was supposed to be engineered to fit.. Oh wells, shit box Nissans.
It would seem to me that if there is sufficient meat on that idler, then machining a couple of mm off its diameter would help? Or, per my original suggestion, can you do something about the alignment of the mount to the front of the engine to lift it up vertically a little? Or a little of both?
Or, a smaller diameter idler to replace that one?
Both your solutions are valid, for now the spaced bracket works and when the car is due for any kind of belt change/timing, crank trigger kit (won't be using Ross after this experience), etc. I will look into replacing the idler OR skimming off parts of it.
Sigh... I hate modifying cars now.
  • 1 year later...
10 minutes ago, chamama said:
I just had similar issue on my r34 gtr where the pulley bracket is hitting the ac compressor belt. Although I have the Ati damper on.
Did you try to get in touch with Ross? They will start to reply then ghost you completely.
Even though I was super polite and understanding.
Guess I'm not some famous tiktok YouTuber, hence they don't give two shits.
How much is it pushing down on the PS belt? What if you slot the top hole in the mounting bracket so it can rotate toward the PS pump and raise the idler enough to get it off the AC belt.
In my experience with some mates drift cars, the belt gets flicked off on the sudden decrease in crank pulley speed on the limiter or downshift in a dog box. We came up with a good fix for the 2J using some Mazda timing belt idler that was just resting on the belt and stopped the belt coming off on some cars that were chronic for it.
Thanks for the advice. We are try to shave off some material from the bottom of the bracket to see if that works. I ideally wouldn’t want to slot the holes cause that would have the chance to move I think
  • Like 1
  • 3 weeks later...
11 minutes ago, Findlay said:
Similar experience with Ross pulley. Can't recommend.
Useless lot aren't they?
Releasing stuff on the market that doesn't do what it's supposed to do without you stuffing about with it and spacing out the spacer lol.
FFS.
51 minutes ago, chamama said:
I think I will try out Frenchy’s power steering kit. Looks like a better solution.
I think throwing the hydraulic power steering system into the trash and converting to electric power steering, e.g. Astra PS pump would solve many issues.
I just put one on my car, nice bit of gear. I've had an astra pump on a car before and wasn't a huge fan, need a way of controlling the pump  speed so it doesn't drive like a '70s Valiant
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
