I was told running a mineral diesel engine oil for a hundred km or so is better than engine flush in petrol engines.
Not flogging the car, just cruising around for a while.
The detergents in the diesel engine oil slowly breaks down the crud, avoiding big deposits from coming lose and blocking small oil galleries/restrictors.
More so for old dirty/cruddy high milage/ poorly serviced engines though.
IMO, a well serviced engine running quality oil, that is serviced regularly shouldn't really need a flush though.
Opinions may vary
Update.... car is alive!! After 4 flushes of oil no more contamination. Car is up and running and all is good. Thanks everyone for your help.
driving normal is good no problems, but when I press the accelerator ( every 1 out of 10)  I hear like a bang noise ( similar to an intercooler pipe popping off noise), I then notice oil from the drivers side block but if you drive normally it doesn't happen.... Any idea what that noise could be and where it's coming from? )only on boost) 5psi.
you can see on the pic the I let manifold gasket is wet from oil. Also noticed oil in the spark plug holes, but only happens in boost, drive normally I don't have the oil leak issue. What can make a "intercooler like popping off noise" and then leak oil on drivers side (only on boost) - see attached pic.
thanks heaps
Edited by VL_Turbo
  • Like 1
Thanks to everyone on this forum for your help. I'm stoked. Car is getting tuned on will inform with the results.
very unusual thing happening, wondering where that loud noise is coming from the drivers side, oil should not be on the intake manifold gasket as per the pic above
Ho All,
Have a small issue with my VLT.
maybe someone could help. driving normal is good no problems, but when I press the accelerator ( every 1 out of 10)  I hear like a bang noise ( similar to an intercooler pipe popping off noise), I then notice oil from the drivers side block but if you drive normally it doesn't happen.... Any idea what that noise could be and where it's coming from? )only on boost) 5psi.
you can see on the pic the inlet manifold gasket is wet from oil. Also noticed oil in the spark plug holes, but only happens on boost, drive normally I don't have the oil leak issue. What can make a "intercooler like popping off noise" and then leak oil on drivers side(only on boost) - see attached pic.
thanks
Well, the oil is fresh and shiny. Wipe everything up, put a go-pro under the bonnet and go for a drive. Look for the squirties. Failing that, tape some rags over places where they won't catch fire and go for a boosty drive. Look for tell tales on the rags. It has to be coming from a clean, filtered source with some pressure (most likely, anyway).
As to the other noise, probably the exhaust manifold or turbo gasket is stuffed. They fart loudly.
Update, tightening the rocker cover bolts and went a bit too tight and cracked the rocker cover near the bolt next to spark plug 4.
can I JB weld it or put some sealant and put it back on or do I need a new rocker cover? Any help would be appreciated 🤦🏽
30 minutes ago, Murray_Calavera said:
Where does your PCV valve live and what does the P stand for?
Hmm. That might be a bit misleading. The P for positive doesn't really mean positive static pressure. It just means that the the crankcase is positively (as in, definitely) ventilated. The driving force for said ventilation is suction from the inlet manifold. The engine is ideally under slight negative pressure when the PCV is open, but will indeed likely be slightly positive when the engine is at idle and the PCV is likely closed.
Nevertheless, Murray's point is valid. You can't properly operate the engine with a crack in the cover. If it breathes at all, it will cause some problems. And it will let oil out.
Yeah, I didn't really think about my example for more then a few seconds before typing it out lol.
It was meant to be a visual aid, probably should have gone with something like, "picture all the skyline's at the track that empty 2L of oil into their catch can after each session".
16 hours ago, VL_Turbo said:
Installed the catch can today, Hopefully that should de pressurise the crank a bit. I've read on the internet some people do use JB weld.
cannot find a spare rocker cover locally in south easter suburbs 😭
Get it welded up by a decent welder. Check it for straightness after it's done.
  • Like 1
  • 3 weeks later...
Yeah mate, better safe than sorry. A reliable TIG welder should do the trick 👍
Edited by Duncan
First post spam link removed
Did you put a new rocker cover gasket on?
Did you check the PCV is installed in the correct direction, AND is functioning?
Just a theory, but where you showed oil coming from, could easily be from the rocket cover.
The bang you're hearing from boosting, COULD be from a stuffed PCV, pressurising the motor with boost, and the bang being it blowing pressure out between the cam cover, and sending oil with it.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
