SMSP has a 95dB limit for track days, however it appears they don't really enforce it, especially when they use the main straight for Roll Racing and those cars are anything but quiet.
Also screamer pipes are such a distraction on track days, you're too busy enjoying the noise to actually be focusing on driving fast lol.
23 minutes ago, r32-25t said:
Depends where the microphone is for the noise meter and I don’t think drag racing has the noise restrictions
Apparently it's at the control tower, yeah I know Roll Racing doesn't have it however the irony is they use the same main straight.
My understanding, is SMSP doesn't have an actual noise limit from the Gumbyment. Other tracks do. Hence they opt in / out of who gets noise restrictions on which days.
That is my understanding from like 15 years ago when I was there.
  • Like 1
17 hours ago, Dose Pipe Sutututu said:
That's so dumb.
It's the age of case of "Even though we can, maybe we shouldn't do it all the time" so they don't annoy everyone
While there's "not a lot" close to EC, that sound does travel.
Roll Racing may align with Top Fuel on some nights, so Top Fuel will be way louder, may as well let it be loud at RR.
When WTAC gets in, it's a HUGE event, better open it up a little (Being on the start finish line, it's nicer if cars keep below the 95dba limit).
95DBA is pretty darn loud. Especially since it's measured at race tracks at 30m from the edge of the track normally!
So think about how loud a car is when it gets book at over 90dba on the road at 1.5m, and then imagine how much louder it is to get to 95DBA at over 15times the distance...
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
