Hello all, I’m in abit of a predicament as my coolant leak fixes are beginning to look like ass, and when trying to find this replacement part to hopefully fix my hose management, it seems long gone. I have tried places like amayama and souqparts. Anyone have any ideas on where to source this?
appreciate any input :)
https://www.sau.com.au/forums/topic/484772-rb25de-neo-rear-water-spigot/
Let's just consider this more fully then, shall we?
Not available anywhere? Check.
What is it made from? It's made from a threaded fitting and a couple of pieces of pipe.
Could it be made in 2 hours by someone with a welder and some raw materials? Maybe a lathe if you want to make the threaded part from scratch? Yep. You bet your girlie arse it could.
Would I make it from scratch if I needed it? Yep. Bet your girlie arse again.
Would I even go to the lengths of getting it cad plated? Probably. At least zinc passivated. It's not hard to do it yourself, but you could always sneak it into a basket at a plater's for a couple of beers.
Useless advice? No f**king way. You are just typical of the weenie approach to everything that the modern generations have adopted. If it can't be 3D printed or bought from an on-line vendor, it is IMPOSSIBLE!
Your attitude is the attitude that sucks. Go file your nails and have a facial.
Edited by GTSBoy
  • Like 1
Yah ! Id remake it ! And remake it in brass so you don't ever have to do it again.
Can you get it off the block ?
If so then take it down to a fitting place and grab a hose barb with the same block thread and main tube size.
Also grab a smaller hose barb to do the right angle one coming out of the main one.
Cut off the threaded end off the smaller hose barb
Drill a hole to the main hose barb the in the same position as the original small one and then press in the small piece and solder it into place.
Did similar to my R33 to replace rusted out, nickel plated, steel fittings over the years.
  • Thanks 1
Hey man do you remember the thread it was? I read somewhere it was a 3/4 bsp but it won’t thread it so now unsure
Nope that was quite some time ago and all I did was take it out of the block and took it to them and said "want this in brass please" !
Of coarse they said " don't have it with the sticky out the side thingy " and then went through the above to make it happen.
I think you will have the same scenario and anyway, one way or another, the original has got to come out of the block.
2 hours ago, PLYNX said:
Also I don't really think its 3/4 BSP as that's imperial !
Probably got to be metric coming out of Japan !
Maybe ! Should be !
Could be wrong though !
Nope. Jap threads are BSP by another name. JIS PT = BSPT (where the T means Tapered, not thread, as is commonly mistaken).
Note that I don't know if the target thread here is BSP/JIS or something else either. But.... if you've got the original in hand, then you have all that you need to know. Just measure the thread.
  • Like 1
    • Maine Coone, did look at but to big and fluffy As for performance dogs, we had Mals at work, performance dogs are fun to watch, but, way to much work for this old rooster
    • Yep, it was only an option on the Q50 Hybrid.  Same in Japan as far as I know. And doesn't use a centre diff like the Suby's do, so not the same as the WRX.  But it also isn't a reactive AWD like other Nissan AWD vehicles are, eg. Murano/Xtrail/etc.
    • You should have got a Maine Coone then. Only thing is they're big. But so cool, and just like a dog. Or, just get yourself a high performance dog. That'll teach you for wanting Parkour indoors 😛
    • Are you thinking of Bens R32? I don't remember if his went through the bonnet itself, but it went through the chassis rail. Brad (RISKIN) bought it, and turned it into a track car. It's funny how anti people are of Jim Berry now. I remember when I pulled mine out (during an engine change) and inspected it and found it cracking badly. At that point in time so many people were even on SAU, were so pro Jim Berry, and that was after Bens GTR exploded his quite publically.
    • That's one of the reasons I got that breed, they look weird, the other reasons are they small, they are very vocal, and run around like they are on crack, I didn't want a breed that just sits around, these two are like kids on red cordial  My daughter has one, and it's a laugh riot, constantly doing Parkour around the house, sits on her shoulder, plays catch, and constantly runs around the house taking turns chasing the dog around, her Bermese though, just lays around with constant bitch face, and just looks on in utter disgust at the cat and dog playing together
