Hi all, I keep finding more and more things to change when doing a clutch change but my mechanic didn't tell me there were other things that could be changed so wanted to check if I got my list right (let me know if anything is missing):
Full clutch kit that comes with all the components
rear main seal (might as well while its out)
clutch fork
input shaft oil seal
Fly wheel remachined
front and rear input shaft bearing (worth changing?)
Yeah no pivot ball for the pull type. I went through the same process last year:
In the end I just ended up getting the spigot bush and clutch fork. The fork not really being needed as it's solid but thought what the heck and did it anyway. Flywheel came with the clutch. There's also the little rubber dust cover that goes on outside. Which in the end also came with the clutch.
I hope you are getting a good clutch. It makes all the difference for actually enjoying to drive the car :)
Yeah will be a basic exedy heavy duty clutch. Do you know if its worth replacing the input and output shaft bearing? I'm guessing they are behind the input shaft itself before the 4 bolts?
14 minutes ago, Duncan said:
I can't see spigot bush on your list, it is worth always changing that when you do the clutch
That will come in the clutch kit, that's actually the main thing + clutch, I need to change because I'm getting grinding noise at idle and when accelerating at certain speeds but goes away when the clutch is in.
Edited by silviaz
Do you know if input and out shaft bearing is behind the input shaft or it's deep in the gearbox? Wasn't able to find info on it.
Upgrade anything you need to remove, that could help performance.
Like the exhaust. While you're there, may as well do the turbo since it touches the exhaust too...
Get the tailshaft double checked too...
  • Like 2
48 minutes ago, Duncan said:
They are both in the gearbox.....box out if they need replacing
I know the gearbox needs to be removed, but was wondering if it's right behind the input shaft as the amount in labour will be alot cheaper to replace it, but will be alot more if it's buried all the way in the gearbox.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
